another thought about HID theft prevention...
Old Jul 24, 2002 | 11:08 PM
TimW's Avatar
The silent but deadly Moderator
what about wrapping a small black wire around the tabs and under the clips and along the wire for the hood release?
if cut, circuit opens, relay sends ground to alarm. alarm makes sound...
seems pretty easy. dunno...
Old Jul 25, 2002 | 08:16 AM
PoLo's Avatar
2-Wheelin it...
Re: another thought about HID theft prevention...
i was thinking this. for those that dont' want the mesh grille and want the stock to stay the same, why not just buy your own mesh and stick it behind the stock grille. a dark one won't be visible at all and it would prevent a thief from cutting the hood release. well it wouldn't prevent it completely, but will delay him. it's all about making it harder for them.
i'm currently making a ghetto mesh that'll go around the hood release area and then swoops in from the bottom so that even if they took the clips out from under the car, they still can't get to it.
does this sound worth it or waste of time? suggestions anyone?
Old Jul 25, 2002 | 10:01 AM
SupaFly's Avatar
Or a combination of the above two mentioned. I'm not to good with electronics Tim, how does that work?
Old Jul 25, 2002 | 10:04 AM
xtantmaxima's Avatar
My alarm goes off when the hood is opened. If you get the Autopage, make sure you add a pin switch to the hood.
Old Jul 25, 2002 | 10:28 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Re: Re: another thought about HID theft prevention...
They don't "cut the good release", they simply reach up from the bumper opening and pop the latch with a screw driver in 5-secs. MAX.
Anything that prevents access to the hood latch area behind the grille will slow SOME of the theives down.
I'm thinking the BEST protection to prevent the "pry through the front" method is some small fine steel cable wrapped around the edge of the lights and SUPER GLUED to the housing. This all depends if you can secure it to the frame with some kind of lock though.
Old Jul 25, 2002 | 11:08 AM
TimW's Avatar
point being...
they didnt even bother with the hood last time.. they ran a hacksaw between the hood and lights.. then yanked. damn... thats crazy
Old Jul 25, 2002 | 11:45 AM
Lumbee799's Avatar
razor wire around hood latch cable?
Old Jul 25, 2002 | 12:06 PM
IceY2K1's Avatar
Re: point being...
Do you think the steel cable super glued/epoxyed around the perimeter of the housing and secured to the frame is a good/bad idea?
It's going to give them something to play tug-of-war with.
REDinLV
Aug 15, 2024 12:30 AM
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
ef9
Oct 4, 2015 08:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
