Koni adjustable shocks or KYBs adjustables
I have someone that wants to replace their stock shocks with nice adjustables. Which shocks are available for you 5th gens???
Re: Koni adjustable shocks or KYBs adjustables
albert
just got my koni installed...thx jay25.
unfortunately.....both shocks are not "officially" available for 5th gen. Cattman modified AGX fronts to fit onto the 5th gen, but the rear shocks are too big for certain brands of spring to settle into the perch (doesnt fit with 5th gen eibach) so some people are using 4th gen springs with cattman's modded AGX
Koni shocks are made for 4th gen and need to cut struts for the front inserts. rears are direct fit and the spring sit into the perch nicely.
Re: Re: Koni adjustable shocks or KYBs adjustables
Re: Re: Re: Koni adjustable shocks or KYBs adjustables
Originally posted by rob van dam
hummm...jay 25....what if i put konis on my eibachs and cut one coil from the front...then my car would sit evenly....hummmm.....call me if you want to make this happen..
Re: Re: Re: Re: Koni adjustable shocks or KYBs adjustables
??? koni fronts use ur stock strut housing so the eibach will sit nicely in there.
So this is what I have to do? the same thing I did to my stock shocks to make my Konis fit on the 5th gen as well??
if then I know what to do then, is not too simple but I can do it this would be my third set of Konis if I was to do it. Albert get that stuff from that dude on the for sale site and it will be direct bolt on. I cut the front coils if your not happy with your drop on the front. It will not bounce bcuz the Koni shock itself is much shorter....never mind Ill explain in person if you decide to do it then.
Re: Re: Re: Re: Re: Koni adjustable shocks or KYBs adjustables
here is a link to my koni and eibach install
http://forums.maxima.org/showthread.php?threadid=138262
tarun900
19
12-20-2021 06:57 PM
04-16-2020 05:15 AM
