What weight syn. oil you using
Old Aug 21, 2002 | 01:52 PM
  #41
PrinzII's Avatar
OG and counting...
Originally posted by iwannabmw
You would be correct.
Cool. I'll be getting 5 quarts of Mobil 1 tomorrow for an oil change.
I have a road trip this weekend and I would like to get the oil changed before I hit the road.
Old Aug 21, 2002 | 03:09 PM
  #42
theMax's Avatar
I have been using mobil 1 5w30 and all is well (I'm on the oil spreadsheet )
FYI I just bought a few cases of mobil 1 0w30 for $2.99/qt at target! Seems some stores are getting rid of the oil that does not sell well. I plan on using it for my winter oil change.
Although I may switch to amsoil because of the new formula of mobil 1...
Old Aug 21, 2002 | 09:19 PM
  #43
palmerwmd's Avatar
Originally posted by PrinzII
After reading this post, I am coming to the conclusion that 5W30 is a good weight for 2k2s and Amsoil or Mobil 1 is a good choice.
By all means, correct me if I am wrong here.
I respectfully disagree.
There is no reason to go thinner than a 10w-30 except in a northern winter (and even then a 10w-30 if a good full syn will be fine almost everywhere).
I say again, the surrent trend to thinner oils is driven by fuel economy considerations by the manufacturers, NOT as by suddenly discovered secret of lubrication, that thinner oils protect better.
The opposite is the case.
The ONLY advantage (other than minute mpg improvements) thin oils offer, is better start-up protection.
And while this is important in overhead cam engines such as ours, it is a non issue when using full syn oils of the proper grade for the season.
Since full syn oils flow so well a 0w-30, 5-30, 10w-30 5w-40 , 10w-40 all flow equally well for all intents and purposes in summer , this would even applyif not a syn.
If a syn ,it would have to get pretty cold to see a difference in flow among those grades.
Even a 10w-40 will protect very well during start-up, if a full syn.
I would never drop below a 40 weight except in a harsh winter.
In KY I will run a 5w-40 in winter.
Fred...
Old Aug 22, 2002 | 06:18 AM
  #44
srbarnes4ever's Avatar
Say Fred, how did the meet go in da 'Ville a few weekends back?! I got stuck in Mexico on business and didn't get into Lexington until midnight on the 9th and just couldn't motivate myself on Saturday. Sorry I missed out on things but keep me in the loop for the next go 'round.
Old Aug 22, 2002 | 06:50 AM
  #45
iwannabmw's Avatar
Fred...
Yes, the current trend to "thinner" oils is fuel economy, but this only effects wear when we're talking a 5W-20 wt. oil. At operating temperature, a 30 wt. oil is a 30 wt. oil. The 5W-30 offers the better start-up prptection and fuel economy while the engine is warming up, but still offers the same protection of a 10W-30 once the engine is warm.
Since PrinzII is interested in Mobil 1, let's look at the numbers for that. At operating temperature, the viscosity of Mobil 1 5W-30 is 9.7cSt, the 10W-30 is 9.8cSt. How is that miniscule difference going to effect wear?? Furthermore, the viscosity index of the 5W-30 is much higher than the index of the 10W-30, indicating the oil is much more stable and resistant to change with the temperature. I don't see the tradeoff in only using the 10W-30.
Yes, a full syn 10W-30 will flow much better than even a dino 5W-30 in colder weather, and will work very well to protect at startup in cold weather. That doesn't mean that a 5W-30 won't protect BETTER.
Old Aug 22, 2002 | 07:21 AM
  #46
bill99gxe's Avatar
Evil Administrator - "The Problem"
I think using the latest 30 weight Mobil 1 oils in any viscosity is a bad idea. Analysis results show the Tri-Synthetics thinning down to just above a 20 weight. With the new SuperSyn STARTING at a high 20-weight, I doubt they will fare any better. In fact they'll probably end up easily in the 20 weight oil range after just a few thousand miles.
Amsoil tends to remain quite stable in a 30-weight over an oil interval, as does ULX-110.
The Mobil 1 synthetic xW/40 "European" formulation looks quite promising though.
Old Aug 22, 2002 | 07:43 AM
  #47
SterlingMist00's Avatar
Mobil 1 5W-30......
Old Aug 22, 2002 | 07:45 AM
  #48
2002 Maxima SE's Avatar
Valvoline SynPower 5w-30. Just changed to syn (from dealer oil change) at the 10,000 mile mark.
Old Aug 22, 2002 | 01:21 PM
  #49
iwannabmw's Avatar
No question about it. I didn't post the Amsoil numbers this time because I didn't want to get into a brand war, I just wanted to discuss viscosity directly.
Old Aug 22, 2002 | 01:43 PM
  #50
MAXRAY's Avatar
i only have 950 miles on my 2k2. when should i which over to synthetic? i've heard around 10K??? sooner or (i hope not) later?
  #51
PrinzII's Avatar
OG and counting...
Fred...
Considering I live in Chicago where the winters can get quite brutal, that is a huge concern for me. Therefore, with what has been said here, I am going with the 5w30.
Old Aug 22, 2002 | 02:46 PM
  #52
palmerwmd's Avatar
Prinz,
But it's still summer and it won't get cold enough to need a 5w-30 for months yet.
In the meantime running a oil too thin for the temps (lots of rough traffic in hot weather left in Chicago right?) will give you less protection than if the proper viscosity was picked.
Actually a 10w-40 full synthetic will flow much better at low temps than a non syn 5w-30, which most ppl consider a good grade for winter (of course we know better and go with syn)
In the middle of a northern winter 5w-30 would indeed be a good choice (even tho there are 0w-40 and 5w-40 full synthetics on the market I would pick over a 5w-30 in winter)
Fred...
Old Aug 22, 2002 | 10:18 PM
  #53
GimmeTorq's Avatar
You never know. We're talking Chicago weather here... 40 degree F shifts in a day? Yep, we got 'em. It's crazy!
Just switched to Mobil 1 5w30 at 5k.
Old Aug 23, 2002 | 12:28 AM
  #54
MAXRAY's Avatar
hmmm...so it's okay to switch to synthetic at 5k?
Old Aug 23, 2002 | 05:27 AM
  #55
buzek's Avatar
Why Not?
I can't imagine it will hurt any thing to protect your engine better-sooner.
Old Aug 23, 2002 | 05:55 AM
  #56
buzek's Avatar
? for Bill
Bill-
In your privious post did I understand correctly that you don't like any of the Mobil 1 30w synthetics? If so, why and what brand do you like?
Old Aug 23, 2002 | 10:53 PM
  #57
E55AMG2's Avatar
Wat
Re: What weight syn. oil you using
MOBIL 1 15w50
Old Aug 24, 2002 | 07:28 AM
  #58
iwannabmw's Avatar
Re: Re: What weight syn. oil you using
Originally posted by E55AMG2
MOBIL 1 15w50
If you like your new '03 you shouldn't use that weight. There's a little more as to why than in the link, but it's a start:
http://forums.maxima.org/showthread....ynthetic+mobil
Old Aug 24, 2002 | 08:01 AM
  #59
E55AMG2's Avatar
Wat
Re: Re: Re: What weight syn. oil you using
I went ahead and listened to my engine, and went so far as to put a tape recorder under the hood, just in case there was something the wind noise drowned out. I didnt notice any tapping or other noises that are caused by oil starvation. That post was made by the owner of a 1997 maxima SE, the oil requirements might be diferent. I had a 2k1 SE that I traded in for this one, and I used 15w 50 in. It also had no problems in the 27,865 miles i put on it last year. I will continue to watch it though, as I always have, for any signs of mechanical troubles.
Old Aug 24, 2002 | 09:15 AM
  #60
iwannabmw's Avatar
Re: Re: Re: Re: What weight syn. oil you using
The oil requirements are identical for the 97. There is no need whatsoever to use a 15W-50 in any of the VQ series engines. It leads to a higher overall oil temperature and flows at a reduced volume compared to the 30 wt. oils. It's also not energy conserving, but it's your car and your money.
Old Aug 24, 2002 | 07:32 PM
  #61
E55AMG2's Avatar
Wat
i burn up a quart of 10w30 oil every 1000mi, 15w50 doesnt burn up. and yes, it is my car and my money
Old Aug 24, 2002 | 07:41 PM
  #62
Green 2kSE's Avatar
Do you mean that your 2k1 SE burnt 1 qt/1000 mi or was that experience from other cars?
Old Aug 24, 2002 | 08:05 PM
  #63
bill99gxe's Avatar
Re: ? for Bill
Originally posted by buzek
Bill-
Based on the oil analysis results, Mobil 1 Tri-Synthetic' viscosity values thinned out to an almost 20-weight oil (all oils usually thin out after a certain period of usage). Since Mobil 1's new SuperSyn synthetic begins with a viscosity range 10% below the Tri-Synthetic oil and BARELY in the acceptable range for a 30-weight oil, I would be real careful running it on any extended interval.
Personally, if I had to use an off the shelf synthetic, I would take a serious look at Mobil 1's new "European" xW/40 formulas available at Auto Zone in my area. Either 0W/40 or 5W/40 is available. It has a good reputation with the VW guys.
Other than that, from the spreadsheet results, only Amsoil and ULX-110 maintained strong viscosity ratings over long drain intervals well into the accepted range for a 30-weight oil.
Old Aug 24, 2002 | 08:08 PM
  #64
E55AMG2's Avatar
Wat
Re: Re: ? for Bill
what you think of 15w 50 supersyn??
Old Aug 24, 2002 | 09:12 PM
  #65
bill99gxe's Avatar
Re: Re: Re: ? for Bill
Bad idea.
I personally wouldn't go over a 10W/40 regardless of circumstance on a VQ. I would sooner sell the car if I had that many bad noises that needed to be quelled.
Old Aug 24, 2002 | 10:43 PM
  #66
E55AMG2's Avatar
Wat
Re: Re: Re: Re: ? for Bill
no noises to be quelled, but just thought that it would be better protedtion, thanks for the heads up
Old Dec 11, 2002 | 09:42 AM
  #67
schuss's Avatar
you guys think it's too late to switch to syn (amsoil 10w40) at 60k?
EDIT: actually, i think it might stick with 10w30, as the pacnw is a pretty mild climate, and the VQ is a pretty tight engine.
suggestions? opinions? thanx.
Old Dec 11, 2002 | 12:37 PM
  #68
iwannabmw's Avatar
60K is not too late at all, as long as the engine is in good shape. VQ's have been switched as high as 130k with no issues and yours is just breaking in
I would recommend the 10W-30 over the 10W-40 for you.
Old Dec 11, 2002 | 12:42 PM
  #69
schuss's Avatar
sweet, thanx! that's what i was hoping to hear.
Old Dec 11, 2002 | 03:12 PM
  #70
Blackgums100's Avatar
List please
Bill,
I have read this thread the whole way threw and as always appreciate the valuable information you and some of the other oil Gurus contribute. Could you quickly make a list of the prefered synthetic oils, of course based on your opinion. I am getting ready to take my 2K1 with 50K on it, in for an oil change and I know with the various manufacturers changing their formulas I am not sure which to use. I had been using Valvoline's synthetic. Thanks in advance.
BTW I had been using Nissan's filter, still have 4 left, are they ok, or are the ones you had listed earlier better?
Old Dec 12, 2002 | 11:28 AM
  #71
Bump
Bump
Old Dec 12, 2002 | 08:33 PM
  #72
E55AMG2's Avatar
Wat
Bad idea.
I ended up trying the 15w/50 Supersyin from mobil 1, and there havent been ay problems. No clicking or ticking on startup (or anytime for that matter). They say the VQ is too tight, but i guess after a solid break in of 11,000 miles in 4 months, it loosened up a bit.
Old Dec 12, 2002 | 08:54 PM
  #73
max'n out's Avatar
DOn't you think 10w - 40 would be good for high boost max's though. LIke a nice red line 10w 40
Old Dec 12, 2002 | 10:24 PM
  #74
Maximam's Avatar
Mobile 1 synthetic 5-30wt. $17.88 at Wal-Mart for 5 qts!
Old Dec 12, 2002 | 10:58 PM
  #75
Linh's Avatar
nice informative thread. As I don't really care about long term reliablity cause I don't plan on owning this car more than ~3 years anyway, I think I'll stick with 5w-30
Old Dec 13, 2002 | 05:07 AM
  #76
Virus's Avatar
Amsoil 5w-30
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
