UDP Installed SES light came on.
Old Aug 1, 2002 | 08:17 PM
asu174's Avatar
Clay Aiken has fancy genitals
How do I get rid of the SES light? The car also initially wouldn't turn over either. I had to give it a wee bit of gas and it started right up. All we did was add on a UDP and new struts......
HELP!!!!!! How do I get rid of the light?
Old Aug 1, 2002 | 08:26 PM
Pmp-n8a's Avatar
try resetting your ecu....it might be freaked out because of the decrease in the weight(UDP)
Old Aug 1, 2002 | 08:41 PM
Sly's Avatar
Sly
Before you reset the ECU, go somehwere like autozone and get the codes read. That'll give you a clue as to what's wrong. It could be nothing, or you screwed up the sensor that's behind the crank pulley. Have you had any driveability problems since the install?
Old Aug 1, 2002 | 08:47 PM
asu174's Avatar
No, just the starting problem....... I'm going to reset the ECU (by disconnecting the battery, right?) overnight and see what happens.....
Old Aug 2, 2002 | 12:17 AM
K Pazzo 6's Avatar
ditto
p.s.-- let us know if any change in feel w/ the UDP
Old Aug 2, 2002 | 03:20 AM
asu174's Avatar
Resetting my ECU did nothing. Light is still on.
Old Aug 2, 2002 | 04:34 AM
UMD_MaxSE's Avatar
Got Bent?
sucks
You need to figure out what the code is somehow....
Old Aug 2, 2002 | 06:26 AM
asu174's Avatar
Still taking forever to turn the engine over. And the light is still on. 2K1HoMax is giving me a scan a little later.......
Old Aug 2, 2002 | 07:45 AM
MichaelAE's Avatar
Which belts did you use? Maybe you are underdriving the power steering too much and it is throwing a code. Might want to get under there and take a look around. There are an awful lot of tight spaces around those pulleys and somebody might have damaged something unrelated to the UDP during the install.
Old Aug 2, 2002 | 07:48 AM
asu174's Avatar
I don't know what belts I used?? The shop ordered them. But they ordered exactly what the Unorthodox manual told us to.
Everything looked like it was running perfectly with the wheel off. But I wasn't there when they installed it, so I don't know.
Crap, I hope nothing is damaged. That would REALLY suck.
Old Aug 2, 2002 | 08:12 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
a friend and myself just installed my udp from the group by about three days ago. i ended up reusing the stock belt for the power steering but both sizes recommended for the alt & compressor would not fit. we had to get one a little longer to make it work. ive got 15k miles on it if that makes any difference, it sure helped getting the stock pulley off. no problems starting up or any engine lights. it was hard feeling a difference the first day because it was 100 degrees outside and my intake was suffering. it finally got a reasonable temperature and i can definately feel the difference off the line. ive got an auto and it helped eliminate some of that lag. no difference in any accessory performance whatsoever.
Old Aug 2, 2002 | 10:08 AM
UMD_MaxSE's Avatar
Got Bent?
The belts UR recommends are kind of a tight fit. You can use slightly different belts as long as the belt deflection is not too much...
Old Aug 2, 2002 | 12:40 PM
asu174's Avatar
Alright, I'm back. I had an interesting day.
My car is totally screwed up. 2K1HoMax took a scanner to my car and my Crank Pulley sensor is not responding. It is either broken or disconnected. I wouldn't think twice about a silly warning light, but I have to crank the key for a solid 20 seconds before the car will start.
I called the shop and they ordered me a new one. $60. I feel responsible because the shop is a suspension shop and I had to coax them into doing the UDP at the same time. Live and learn. I just want my damn car back to normal.
Justinmc760
Aug 23, 2015 03:10 AM
Samedi
Aug 13, 2015 04:05 PM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
