Out with the Franken, in with the Injen...
Old Aug 2, 2002 | 04:59 PM
dblrr900's Avatar
So I had enough of the Frankentake today. I was on the DC beltway and it was serious hot and serious traffic. I had been driving for about 40 minutes. I went to hit the gas to jump over to the next lane to exit.... bluhhhhh (huge Bog) almost stalled out, and got rear-ended. So I started hitting the gas a lot to test what was going on and I can hear the intake suck real hard then the car would bog. It took forever for the car to pick up.
It is clear that in high-humid heat the car doesn't do well with real hot air that obviously is being taken in by the frankencar.
I came home and called George at Adventon right away. He is a real nice guy and wants customer feedback. I recommend talking with him anytime you need something or want someone to track something for you. Nice guy.
Anyhoo, when the Injen gets here BigDog and I are setting up a Dyno appointment to test the two pieces before and after. I will keep you posted.
Old Aug 2, 2002 | 05:02 PM
BigDogJonx's Avatar
Dont worry fellows, I will be there with either a video camera or something to document the dyno and a rack of pics with my Digi cam.
Dixit
Old Aug 2, 2002 | 05:09 PM
maximadave's Avatar
detailerdaveb@gmail.com
I went from a Frankencar to an Injen as well
Old Aug 2, 2002 | 05:12 PM
deezo's Avatar
Re: Out with the Franken, in with the Injen...
It's been the same here in MA and I've seen no issues with the intake in this weather. I used to feel the bog with the stock box though.
Old Aug 2, 2002 | 05:27 PM
MichaelAE's Avatar
I went from stock, to Berk, to Frankencar, to Injen. I wonder what the next logical step is.
Old Aug 2, 2002 | 05:31 PM
ajahearn's Avatar
It would really help if you could compare with stock and end the repeated "does a CAI/HAI improve performance" debates. Either way I look forward to seeing the numbers.
Old Aug 2, 2002 | 05:32 PM
Foglght's Avatar
the next logical step is a high performance FORCED induction!
Old Aug 2, 2002 | 06:18 PM
maximadave's Avatar
S/C
Old Aug 2, 2002 | 10:15 PM
KLOOGY's Avatar
L33t BMW Drivah
I reaally dont see how you could blame that on a Frankencar, or a Berk. I wonder how much modding you guys have done to other cars. I personally think this is an absurd thread. But to each his own.
Old Aug 3, 2002 | 02:14 AM
serin's Avatar
yeah, i'm not sure i understand the logic either. how do the different intakes each handle environmental moisture and temperature differently? it occurs to me that hot humid air is still hot and humid regardless of what filter and/or midpipe it's passing thru.
i honestly don't know, so no flaming, just explain to me what i'm missing here.
Old Aug 3, 2002 | 05:02 AM
buzek's Avatar
It's even hotter in the engine bay!!!
Hot air outside is one thing 95 deg., but its 300 in the bay with the fans from the rad. blowing right at your intake. At least with an ingen the intake is away from the heat from that fan.
Now I see why Nissan put that goofy box on there, to insulate the air from the radiator heat blowing INTO the engin bay.
Old Aug 3, 2002 | 05:22 AM
soundmike's Avatar
Very sound, Mike
Re: It's even hotter in the engine bay!!!
But i thought the Injen had the filter sitting directly behind (e.g. within the path) of the radiator?
Old Aug 3, 2002 | 06:00 AM
buzek's Avatar
Re: Re: It's even hotter in the engine bay!!!
I don't have one but it looks like it is below (the radiator)? Any one.. help us out.
Old Aug 3, 2002 | 08:06 AM
dblrr900's Avatar
the intake on the Injen sits just below the radiator. The air that gets brought into the intake from Injen should be at least 20 degrees cooler than the air sitting at the top of the engine bay where the Franken is. This is the science between CAI and HAI.
Kloogy - I have modded a few cars, Civic, w/ B18 Swap. I had a 97 Maxima, and now also have a GTI 337 w/ 1.8T. I am not the engine master but I have modded quite a bit, and I understand what the Injen will do for me vs. the Franken.
I also found yesterday whnen I took the Franken out for some cleaning that the Filter is rubbing the negative cable so bad that the cable is loosing its covering and getting to the metal. And the K&N is literally getting worn into the filter, the metal is almost gone where the cable is rubbing back and forth.
Short story is this thing has to come out.
I wish the franken bracket I got sent actually worked but it didnt, it put my intake too high and the hood would smash it.
Old Aug 3, 2002 | 08:09 AM
Y2KSESteve's Avatar
As did I. My SES light went off with the Injen too!
Old Aug 3, 2002 | 08:33 AM
buzek's Avatar
Let's all convert!!!
Who can give us the best deal...possibly a GB
Old Aug 3, 2002 | 02:55 PM
dblrr900's Avatar
Re: Let's all convert!!!
WWW.adventon.com
Give them a call. George might do it. He was suprised that there was such a large Max following.
Old Aug 4, 2002 | 09:43 AM
BigDogJonx's Avatar
Re: Re: Let's all convert!!!
WWW.adventon.com
Someone already tried it with Adenton and I they they came back with saying George is already blowing all his competitors prices away and cant really go much lower. I read it somewhere in the Group Deals section.
Dixit
Old Aug 4, 2002 | 11:24 AM
PCGuRu2K's Avatar
Re: Re: Re: Let's all convert!!!
Dixit
It's already I think only $217.. That's pretty darn cheap compared to all the other places..
Old Aug 4, 2002 | 06:03 PM
Tony Fernandes's Avatar
Re: Re: Re: Re: Let's all convert!!!
I don't claim to know the scientific reasonings and benefits between my old Frankencar and my Injen. I'm fairly well informed and could debate the two fairly well, but bottom line is that I am much happier with my Injen. Throttle response was vastly improved and there is no bog after sitting in traffic. I miss the impressive WOT sound of the FC, but the Injen sounds good in its own way, especially at low RPMs. However, there is nothing wrong with the Frankencar...I liked it very much for the time I had it!
Tony
Old Aug 4, 2002 | 07:02 PM
doublea's Avatar
Move to Canada where the air is cold and dry.
AA
Old Aug 4, 2002 | 07:42 PM
MichaelAE's Avatar
AA
I'm in Seattle...that's about as close as I can get and still be governed by a corrupt, hypocritical government...so I'll stay down here thank you.
skyjay617
Mar 16, 2003 05:11 PM
mikey62681
Feb 11, 2003 06:52 PM
mohfo
Aug 23, 2002 11:51 AM
emax02
Feb 27, 2002 07:24 PM
