debadging nissan emblem from trunk
Old Aug 2, 2002 | 05:10 PM
MAXRAY's Avatar
i have successfully debadged the "MAXIMA" and "SE" and the "dealer emblem" from the trunk. but, has anyone removed the nissan "hamburger" emblem from the trunk of a 02? i've heard there are there are two holes??? any fixes? or will it need body work/paint? will the entire trunk need to be painted again or is there a cheaper but clean fix? any pics? thanks.
Old Aug 2, 2002 | 09:49 PM
slo-ryde's Avatar
Re: debadging nissan emblem from trunk
The "Nissan" emblem on the trunk is located by two small pins that mate with holes in the sheet metal. If you remove one of the liscense plate lights and peek inside with a flashlight you'll see them. I took off the "MAXIMA" and "GLE" emblems shortly after buying my car but decided to leave the "NISSAN" emblem because of the holes.
Old Aug 2, 2002 | 10:10 PM
mykmar10's Avatar
Re: Re: debadging nissan emblem from trunk
How do you remove the Maxima & the SE emblems from you car without messing up the paint finish?
Old Aug 2, 2002 | 10:12 PM
KLOOGY's Avatar
L33t BMW Drivah
Re: Re: Re: debadging nissan emblem from trunk
I took Maximadave 's advice. Let it sit in the sun for an hour, and used dental floss. I was done in less than 30 minutes.
Old Aug 3, 2002 | 12:44 AM
slo-ryde's Avatar
I just popped them off with my fingernail. They are made out of plastic and are attached with a thin material that has sticky on both sides. There will be some sticky residue left on the paint that you can remove with a mild solvent (WD40 works pretty good) then apply some fresh wax afterwards.
Old Aug 3, 2002 | 02:02 AM
mingo's Avatar
just buy a tube of bondo and patch up the holes.. taht's what i did. it doesn't look all that professional but imo looks alot better than having a badge there.
Old Aug 3, 2002 | 09:21 AM
areX's Avatar
dental floss, credit card, Turtle Wax's Bug&Tar Remover, and a little patience. voila'!
Old Aug 3, 2002 | 01:21 PM
BLaZin 2k MaX's Avatar
I thought about doing that but come to think about it, Your *** is gonna look naked without at least the MAXIMA.
Old Aug 3, 2002 | 01:27 PM
Loe max's Avatar
I just used a blow drier and fishing line, done in about 5 mins. I too thought the rear looked to naked. I think the badges break up the sea of ugliness. I hated the gold emblems that came with the car, so I painted MAXIMA/GLE matte black, like the SE.
Old Aug 3, 2002 | 02:02 PM
areX's Avatar
not that bad on a 5th gen. look at my pics and other people's pics. it's not nearly as bare as the 4th gens.
Old Aug 3, 2002 | 02:19 PM
witeenigma's Avatar
the need for better power/weight ratio by a couple oz. doesn't outweigh the thought of being generic
adamgalazka
Feb 5, 2023 08:24 AM
rbaker100
Sep 6, 2015 02:46 PM
coasterswim
Sep 2, 2015 07:43 AM
Hailstatejig
Sep 2, 2015 06:52 AM
