what would be the best intake?
since i have come to realize that the high flow air intake is not as good as i have heard, then what air intake system woud be best to install that would increase hp.. i have read somewhere ont he net of a intake system called something like the weapon dragon where is guarentees a 9 hp boost. i dunno, i am skeptical and cannot find this site again.. i am looking for a solution to answer this questions of which intake system can output top noch preformance..
Here's your web site, speedracer . . .
http://www.weapon-r.com/main2.html
I don't see that there's any particular advantage in the Weapon-R intake. I'd recommend you stay with the tried and true solutions: Stillen Intake, JWT Popcharger, or Place Racing Cold Air Intake.
I seem to remember someone running a dyno test on his Maxima first running a Stillen Intake (or JWT Popcharger) with the hood closed and then running a Place Racing CAI. There was practically no difference in the results. I guess that once the vehicle starts moving, air circulation under the hood eliminates any problem with engine heat getting to the intake.
You can purchase a JWT Popcharger from Phuong for $122.00 including shipping. Contact him at gr_racing@yahoo.com.
There doesn't appear to be much difference between the popcharger and CAI on the 5th gens.
http://forums.maxima.org/showthread....threadid=10524
Speedy, I suggest you don't give in the manufactur's claims about gains w/ the intake. They are usually bs. Plus if I remember correctly, the weapon R uses a foam element, which might be good for flow but is absolutely crappy for dirt particle filtration. It doesn't even look like they use oil to help trap dirt. Up to you, good luck
maxima297
Sep 30, 2015 03:32 PM
