FIAMM air horn question (blown fuses)
Old Aug 12, 2002 | 06:45 PM
theMax's Avatar
I installed the dual FIAMM air horns a few weeks ago.
I replaced the front horn with the air horn and left the second horn next to the belts.
Now if I hold down the horn for more than a second the fuse blows. (10A)
Whats going on
Old Aug 12, 2002 | 07:11 PM
Maksim2000's Avatar
Re: FIAMM air horn question (blown fuses)
Whats going on
In the box with the FIAMM horns there was(should've been) a relay - use it ! Your stock harness is not designed to handle the load.
Old Aug 12, 2002 | 07:43 PM
theMax's Avatar
Re: Re: FIAMM air horn question (blown fuses)
The horns came with 2 air horns, tubing and a metal cyinder.
I never opened it but I assumed it has a pump inside (and maybe a relay) Anyway it has a + and - on the bottom.
I hooked the + up to the old horn and grounded the -.
Is there another way to hook it up? If its a relay, where do I connect the power?
Old Aug 12, 2002 | 07:59 PM
Maksim2000's Avatar
You can either
a) be stupid/brave and replace a horn fuse with a 20 amp one... (That's what I did) Don't later if your car catches on fire
b) be smart/trick and get an automotive relay and run a separate 20 amp fused line of the battery thrugh the relay to the horn and control the relay with a stock signal
On an ISO relay I would connect stock horn connector to "86" and ground (chasis) the "85". and then run a wire with an inline fuse(20A) from the plus of the battery to the "30"("30/51") and then run the wire from the "87"(!Not "87a") to the "+" of the horn compressor and then ground the "-" of the compressor
Old Aug 12, 2002 | 08:03 PM
theMax's Avatar
You can either
Connect stock horn connector to "86" and ground (chasis) the "85". and then run a wire with an inline fuse(20A) from the plus of the battery to the "30"("30/51") and then run the wire from the "87"(!Not "87a") to the "+" of the horn compressor and then ground the "-" of the compressor
Thanks! relay time.
Use the horn + as a signal to turn on the relay and take power from the battery. Cool!
tsi6001
Oct 3, 2022 10:23 PM
rbuswell
Nov 17, 2016 04:54 AM
vingodine
45
May 21, 2016 12:46 PM
jerrod99_se-l
Aug 24, 2015 10:24 AM
Balkins
Aug 12, 2015 06:39 AM
