Sunroof problem
Old Aug 16, 2002 | 06:37 AM
Y2KSilvahSE's Avatar
Sunroof problem
Anyone have sunroof opening/closing problems? This just started on my 2k SE after working PERFECTLY since bought new. You go to slide it all the way open bu sliding the switch all the way back for the one touch opening function, and it moves about 3 inches and stops. It will open all the way, just 3 inches or so at a time. Same for closing also. Weird thing is I used it yesterday and it worked perfectly...what gives? The search didnt yeild anything useful.
Old Aug 16, 2002 | 09:09 AM
Colonel's Avatar
Old Fuddy Duddy
Re: Sunroof problem
Dunno, but I want to point out to people this is 2K not a 2K2....we dont have the electronic gizmo reset that the 2K2 can do.
Old Aug 16, 2002 | 09:28 AM
jjames's Avatar
Re: Sunroof problem
You need a new motor, bro. NO, you can't reset it. Mines the same way. Either live w/ it or have a new motor installed. If you get the new motor, I'd have the dealer install it. Let THEM be resposible for ripping your $1,000 headliner.
I have an estimate in my car. I believe it's $298.
Old Aug 16, 2002 | 09:55 AM
][ 35's Avatar
what's the electronic gizmo reset ?
Old Aug 16, 2002 | 10:14 AM
Nyc2kMax's Avatar
What u can try before going to the dealer is disconnecting the batery and leaving it off for about 20 minutes then reconnect then trying it. If problem persist then you have no choice to go to the dealer and let them take care of it.
Old Aug 16, 2002 | 10:17 AM
Re: Re: Sunroof problem
[QUOTE]Originally posted by jjames
[B]You need a new motor, bro. NO, you can't reset it. Mines the same way. Either live w/ it or have a new motor installed. If you get the new motor, I'd have the dealer install it. Let THEM be resposible for ripping your $1,000 headliner.
Holy crap, a new sunroof motor? on a 2 yr old Max? Well it only has 28 k on it, so they WILL be fixing it free ...Along with the coil tsb...
Thanks for the info dude
Old Aug 16, 2002 | 11:26 AM
Thanks nyc...I will give that a try this weekend. Sure is some weird arze wiring in those things if it fixes it...Now that you mention it, I may have seen something like this in the .org a while ago...I wonder if it just "happens" or could the 98 degree weather/70 per cent humidity was a contributing factor
Old Aug 16, 2002 | 11:35 AM
jjames's Avatar
It just happens. This has been a problem for several of us. Try the battery thing, and let us know if it works. I'm all for saving 300 bones.
Old Aug 16, 2002 | 12:24 PM
Colonel's Avatar
Old Fuddy Duddy
He he...tech speak! No, in the 2K2+ there is a procedure that "resets" the sunroof system. It is listed in the manual.
I guess (read:assume) there is more electronics involved for all the "1 push" functionality. My wifes Focus has all that crap and they also list a procedure to reset the sunroof system. Apparently it does not take much to upset/confuse these systems.
Old Aug 16, 2002 | 12:30 PM
"Apparently it does not take much to upset/confuse these systems"
Thats for sure...all I did was shut off the car...
Hopefully the battery unhook deal will work...
I'll let you guys know one way or the other.
Thanks again .org!
Old Aug 16, 2002 | 12:38 PM
jjames's Avatar
Thanks again .org!
*** It won't. I hope it does, but it won't.
Old Feb 3, 2003 | 08:09 AM
Teser's Avatar
Re: Sunroof problem
Pretty much same thing happened to my 2kSE this morning. Finally a sunny day after few weeks of cold winter, and I wanted to get the roof open, but to my surprise it opened only about one inch at a time and I had to press the button again and again to open it all the way. another thing is that both buttons now do exactly the same job of opening the roof all the way and back to closing it and back to moving it to open up.
So, naturally, the first chance I get - I get on the maxima.org looking for answers. A little search, and I see this thread. So I'tried to disconnect the battery for 5 seconds and connect it back. Then do the "reset" described in a different thread, by turning the ignition to "ON", closing the roof, pushing the up button and waiting for the sunroof motor "bump", and the damn thing works again the way it should!
Thanks all.
BTW, more and more to me it seems like, the first thing that we should do if there is something strange happening to the car, is to disconnect the battery and reset the ECU. If that does not help, then look for answers on the .ORG
Old Feb 3, 2003 | 08:14 AM
Thanks all.
Yup, worked perfectly for me too...and yea, seems like most electronic functions go thru the computer. definitely a good place to start in your diagnosis.
Mar 12, 2020 12:06 AM
Blkkn8
Sep 15, 2015 06:57 PM
Vequity
Sep 10, 2015 05:26 AM
mikebla
Sep 3, 2015 05:37 PM
