My First problem with car happened...
Old Dec 14, 2000 | 08:28 PM
Maxx Atlanta
Today...I was driving down a street that has a slight decline to it. Took my feet off the gas to ease the speed, then press the accelerator slighty and my RPM levels along with engine started to skip...I did it again...and IT DID IT AGAIN!!! hhhmmmm.
Anyone experience any unsteady idiling/aceleration under 2000RPM's!!
Not sure if it's the gas...but I do use STP gas treatment on every fillup of premium gas!!
Old Dec 14, 2000 | 08:43 PM
TimW's Avatar
The silent but deadly Moderator
i was told to never
use an additive in my gas. it fouls the injectors. When my car was not idling well, they told me to use some injector cleaner, but to only use 25%-50% of the recommended amount.. and to only use it once, see what happens, then maybe some more a few tanks later.
Old Dec 15, 2000 | 06:43 AM
sentient
Manual says not to
add anything to your gas, the engine says it's not designed for it. That's all I remember when skimming the manual.
Old Dec 15, 2000 | 07:03 AM
Paul6speed's Avatar
I saw something in the paper about this. Nissan recommends against using additives with the type of injectors they use.
Old Dec 15, 2000 | 08:08 AM
MOBOY's Avatar
I have
This has happened to me a couple of times early in the morning. It seems like the car is not warmed up all the way and....sometimes even when the car is warmed up it takes a mile or two going down the road to get the juices flowing.
Old Dec 18, 2000 | 03:30 PM
DOM's Avatar
DOM
What year is your car? I have a problem with mine when it is cold. It jerks or skips. I took it to the dealership and of course, it doesn't do this when they drive it. Drives me nuts!! Mine occurs befor 2000 rpms also. Does this sound similar?
Old Dec 19, 2000 | 02:08 AM
Max2000's Avatar
I have the same thing
if I don't let my car warm up at least 30 sec to 1 min... when I start driving... on the second gear.. it will jerk/skip... dunno.... it only happens when it's really cold outside and the car has been sittign over night... I know it's no use to take it to the dealer.. cuz they are just gonna tell me "can't duplicate the sympton.."
Old Dec 19, 2000 | 08:03 AM
wdave's Avatar
Re: I have the same thing
They could duplicate the symptom if they started with the car cold, but they couldn't do anything about it. I had the same "problem" with my '94 Protege, suspect it exists to some degree with most modern cars. It's because smog controls cannot allow the engine to run as rich as it needs to be while warming up.
Dave
Old Dec 19, 2000 | 08:33 AM
Dave B's Avatar
Not DAVEB the parts guy
No need to worry guys, my 96 5 speed does the same thing. It is annoying, but is easily avoided by using a lower gear to stay off the annoying 1800 rpm "jolt". My car only does this during the first moments of running during colder weather. Since it only happens during warm up and in cold weather, I think it is pretty clear that this is a special "rich running" fuel program intended to warm up the motor as soon as possible. What you are experincing is most likely a lot of gas being dumped into the cylinder and the low rpm isn't burning it fast enough (ie flooding the motor). The ECU sees that the motor is becoming slightly flooded and starts in with a new program.
With a cold motor, you don't want to run it at a really low rpm anyways. You should keep it in the 2500-3000 rpm range. Even on the coldest day, you should start you car and begin driving as soon as the oil pressure is at normal or about 30-60 seconds after starting it. A engine under load will warm up much faster.
Dave
Old Dec 19, 2000 | 06:13 PM
DOM's Avatar
DOM
So this isn't anything to worry about, right? It isn't damaging to my car then? I was considering trading my car in because of it. My Nissan dealership said that my car was the only one that did it. After I put in the Stillen Intake, they returned my car to me and said they can't look at it because of my mod.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Samedi
Aug 13, 2015 04:05 PM
erniel
Aug 8, 2015 09:32 AM
yat70458
Aug 3, 2015 01:16 PM
