Moms car won't start
Old Aug 20, 2002 | 07:41 PM
Conrad283's Avatar
I need a truck
when i try to start my moms 2001 max all i get is a vaccum sound ... i checked the manual and i didn't get anything ...... has anyone experienced this problem
Old Aug 20, 2002 | 08:38 PM
Green 2kSE's Avatar
Re: Moms car won't start
Can you describe in more detail this "vacuum sound"? Do the lights come on, is there gas in the tank?
Old Aug 21, 2002 | 04:49 PM
Conrad283's Avatar
I need a truck
Re: Re: Moms car won't start
full tank of gas .... everything works except when i turn the key there is a vaccum sound and the engine doesn't turn over
Old Aug 21, 2002 | 05:30 PM
mdeal's Avatar
Try depressing the brake, moving the gear shift from park to drive then back to park, take the key out, put the key back in, put your foot on the brake, and try starting it.
Old Aug 21, 2002 | 07:40 PM
NYC2SD's Avatar
Vacum sound might be the fuel pump coming on.
Old Aug 21, 2002 | 07:44 PM
Igor911's Avatar
I have this prob here and their.
Just move the shifter a lil bit and it will start.
Old Aug 21, 2002 | 08:16 PM
ajahearn's Avatar
Vacuum sound
You need to use a different description as vacuum sound is not enough. One thought is that your starter is failing (sound is the starter spinning but not engaging engine).
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
