More brake dust in rear?
Old Aug 23, 2002 | 05:57 PM
asu174's Avatar
Clay Aiken has fancy genitals
I've been meaning to ask this one for a while now, but I have noticed that I have to wipe off around three times as much brake dust on my rear wheels as I do from my fronts. This is odd because I have always driven FWD cars and they ALL have had more dust in the front.
Are you guys the same way or am I abnormal? I get a TON of brake dust in the rears. Any ideas?
Old Aug 23, 2002 | 06:30 PM
MAXRAY's Avatar
Re: More brake dust in rear?
think that's odd. even on my rear wheel and four wheel drive cars/suv, i get more brake dust in the fronts.
Old Aug 23, 2002 | 07:14 PM
Greg's2kGLE's Avatar
That is kind of odd. You might have a problem with brake wear or something. The fronts are used more, that's why there is more brake dust in the front. The front brakes a applied first then the rear, if needed. (I think it's something like that)
Old Aug 23, 2002 | 10:45 PM
asu174's Avatar
So do I just need new rear pads ya think?
Old Aug 23, 2002 | 11:06 PM
PHATMAN5050's Avatar
If what 'greg's2kgle' is correct, what you need to do is stop slamming on the brakes. haha I wouldn't worry about it unless you hear squeeling when you stop or you think it takes longer to stop or something of the sort. Basically, if it isn't broken, don't fix it.
Old Aug 23, 2002 | 11:29 PM
Green 2kSE's Avatar
Maybe your emergency brake needs an adjustment? From what you are saying it seems the rear brakes are engaging before the front brakes, which isn't normal. Are you on original pads?
Old Aug 24, 2002 | 05:25 AM
asu174's Avatar
No, I don't think so. The dealer put in new ones about 10,000 miles ago. This problem has been ongoing since I purchased the car.
Old Aug 24, 2002 | 06:02 AM
maximadriven's Avatar
Im with Green on this one...When I got my car the rear wheels would turn charcoal black. It turned out to be a stuck brake caliper. There is no way you should be getting that much brake dust on your wheels. There is definately something wrong back there.
Old Aug 24, 2002 | 08:41 AM
mdeal's Avatar
I seem to get get more brake dust on the rears as well.
Old Aug 24, 2002 | 11:28 AM
NYC2SD's Avatar
Actually all your brakes are applied together, however your fronts do the majority of the stopping as intertia shifts the weight of the car foward when the breaks are applied. That is why your car noses down during a hard stop.
Old Aug 24, 2002 | 12:54 PM
UMD_MaxSE's Avatar
Got Bent?
OEM rear pads are organic while the front OEM pads are semimetallic. The OEM rear pads seem to dust more....
Old Aug 24, 2002 | 01:59 PM
Hmmm, I didn't know that. I know about the inertia thing though.
Old Aug 24, 2002 | 02:11 PM
Igor911's Avatar
I get a TON OF DUST eventhough im running stillen rotors and axxis master metal pads???? was i lied to when i bought them that they produce less dust?
Old Aug 24, 2002 | 02:47 PM
schuss's Avatar
yeah, my rear end is dustier, too, both with the stock stuff and since i've replaced the shoes. and i'm not even doing (that many) handbrake turns!
Old Aug 24, 2002 | 03:30 PM
2K1HoMax
either ur cruisin around with the E-brake on, which i really doubt u would, u have a caliper problem in which the might be appling too much force (this i very rare, and usually just shortend the pads life down by approx 25% or so) or might be just slammin ur brake like posted too often. what kind of pads do u have anyway? were the rotors resurfaced with the brake job of they are diff pads??
Old Aug 24, 2002 | 03:40 PM
asu174's Avatar
They resurfaced the rotors and put in new pads.
Old Aug 24, 2002 | 03:48 PM
JSpecMax's Avatar
Thats one way to get rid of the horrendous understeer problem...
Old Aug 25, 2002 | 01:51 PM
2K1HoMax
well then this is just wierd, by standard brakes are suposed to have approx 70% of their clamping power up in the front. i checked my pads like 2weeks ago and the rears are just fine, it could probably go til 40K miles,, but the front will have to go around 25K topps. im at 18K miles right now. im thinkin ill just resurface the rotors the first time and when i have to replace them ill just throw on the stillen cross drilled rotors, besides they cost less then the OEM ones. btw has any1 tried ceramic pads yet? ive put a few sets in car and there is no noise at all, also very low to no dust.
Old Aug 25, 2002 | 08:43 PM
Cfbrenton1's Avatar
NAV?
Hey,
I happened to notice in your picture that you have the NAV. My question is abou the bose stereo. Does yours only go to a volume of "31"?
Old Aug 25, 2002 | 09:39 PM
slickrick's Avatar
mine goes to 31, but when i play it on 19, it shuts off. i have non bose 2k2 se.
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
A32goldylocks
Sep 2, 2015 06:39 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
