Is a 225-45-18 tire safe for a 18-8.5 wide wheel?
Old Aug 23, 2002 | 07:48 PM
russ's Avatar
Want the extra sidewall compared to a 40 series tire will the 225-45-18 work on that size wheel?
Old Aug 24, 2002 | 03:31 AM
irvine78's Avatar
Re: Is a 225-45-18 tire safe for a 18-8.5 wide wheel?
go wider...at least 235s...even then, your side wall is going to crown..i say go with 245/40/18s..
Old Aug 24, 2002 | 07:34 AM
PIONEER's Avatar
225 is to narrow for 8.5inch rim. 245z the way to go.
Old Aug 24, 2002 | 07:42 AM
MAXRAY's Avatar
i would also go w/ 245/40/18. it would give side wall of 9.8 cm.
225/45/18 gives 10.1 cm of sidewall...only 3mm more!!! not worth it. plus, 245/40/18 will fit a 8.5" width rim better!
Old Aug 24, 2002 | 11:54 AM
irvine78's Avatar
225/45/18 will give you 3mm more if it weren't on a 8.5inch wide rim..if it were on that wide of a rim, it would stretch and crown..less sidewall..
Old Aug 24, 2002 | 11:56 AM
MAXRAY's Avatar
that's true. so basically, russ, don't do it. go for 245/40/18.
Old Aug 24, 2002 | 03:48 PM
russ's Avatar
[QUOTE]Originally posted by MAXRAY
[/QUOTE My wheels have a 34 offset so will the 245-40-18 tires rub with the stock suspension.Thanx for all the info guyz!
Old Aug 24, 2002 | 05:36 PM
MAXRAY's Avatar
on stock suspension, you shouldnt' have rubbing prob's.
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
