coolant and air bubble?
I heard that air bubble results when you change coolant the wrong way. How can I avoid it? What is the proper way of changing coolant? When I search the forum, no one talked about air bubbles. How big of a problem is it?
valves
You would need to open the valves while filling and then close them when you are done (fluid starts coming out). I believe the one on the radiator uses a hex bit. I don't know about the engine body ones.
Re: coolant and air bubble?
checked ESM
I just checked my 02 ESM and karguy is correct. No relief valves on the 02 Maxima. My wife's Quest needed the relief valves opened and I assumed the Max would be the same. The ESM says fill the radiator and reservoir tank. Run the motor and then check (and refill) radiator and reservoir.
tarun900
19
Dec 20, 2021 06:57 PM
