Aftermarket horn replacement
Old Aug 31, 2002 | 06:58 AM
MAXRAY's Avatar
i'm interested in replacing the weak oem horns w/ some aftermarket ones. i've done a search and seems that the easiest replacement would be w/ fiamm freeway blasters e&f. are these true "plug-n-play"? no mods necessary?
anyway, i was unable to see any pics of the install. one thread had little red x's instead of pics. can someone please repost some instructions and pics? i'm not even sure where the horns are. i'm assuming we have 2 horns in our max...one in the engine bay, the other behind the grill? that's about all i've gathered...is that correct? any help would be appreciated.
Old Aug 31, 2002 | 07:25 AM
MAXRAY's Avatar
just looked under the hood...i'm not sure what i'm looking at, but seems to me that there are two horns mounted between the grill and the radiator??? is that right for a 2k2? on searches, people have posted that there's one inside the engine bay by the coolant and the other between the grill/radiator. confused...
Old Aug 31, 2002 | 07:51 AM
Tanman's Avatar
I found these threads, they don't have that much information but it will help you get started:
Max34 fiamms
Fuse issue
I think you should go buy a set and check the instructions. They'll probably answer most of your questions. I plan to do the same.
Old Aug 31, 2002 | 01:20 PM
MAXRAY's Avatar
well, i just went out to the local auto parts store and bought
FIAMM highway blaster E&F. and it was a direct replacement for the factory horns. btw, for 2k2...BOTH horns are mounted between the grill and the radiator. definitely a good upgrade for $25. but, not as impressive as i thought it would be.
Old Aug 31, 2002 | 02:44 PM
2001SE's Avatar
I think its enough upgrade then those wimpy crappy stock ones.
sometimes i honk at people walking down the street coming from behind real close to the sidewalk , and they jump pretty high when i honk
then i knew its a loud horn
Old Aug 31, 2002 | 06:05 PM
Tanman's Avatar
Maybe you didn't install them correctly? Check the fuse thread or maybe someone else knows?
Old Aug 31, 2002 | 06:09 PM
MAXRAY's Avatar
i'm pretty sure they're working properly. i tested each one individually. they are definitely louder than stock. just not as impressive as i thought they would. defintely worth it.
Old Aug 31, 2002 | 07:32 PM
Tai Mai Shu's Avatar
If you have any problems finding the horns, just stand under the hood and have someone hit the horn
Another horn solution is to use the factory horns from the I-35. They do not use your typical asian import horn, but more the american cars style. Unsure of p/n's or cost, but it's a direct bolt on.
mvm062
Nov 30, 2020 09:00 AM
JoshG
21
Sep 4, 2015 09:04 PM
A32goldylocks
Sep 2, 2015 06:39 AM
maxipower
Aug 21, 2015 11:10 AM
PhalC1
Aug 5, 2015 02:36 PM
