Meguiars Endurance tire gel....how do you get the build up off
Old Sep 2, 2002 | 07:36 AM
rntmax02's Avatar
I use this stuff and it works good but I'm finding I'm getting build up in and around the lettering...I can't find anything that cuts through it except for more endurance which will smooth it out but it keeps getting thicker
Any Ideas from other users......
Old Sep 2, 2002 | 07:50 AM
PrinzII's Avatar
OG and counting...
If you are referring to the infamous browning, I would hit the nearest Auto Parts store and buy the Espree wheel cleaner (green formulation). The reason I say that is it's gentle enough to use on tires and it is effective.
However, if you want to try something else, try this: http://www.properautocare.com/hi-c32.html
If you want to get a good tire protectant, check out either Meguiar's #40 or Lexol Vinylex. I have used both and found myself using the vinylex more because it's a water based product and I prefer more of a matte finish as opposed to a high gloss. Another choice is Eagle One's Tire Wet.
Old Sep 2, 2002 | 07:52 AM
2000 SE's Avatar
I use a product called bleach white for lettered tires and blackwalls. You spray it on, let it sit for like 30 seconds, then give it a little scrub with a brush and rinse. My tires look like fresh rubber when dry, they I apply my shine.
Don't get it on your wheels if they are hot, it might spot.
Old Sep 2, 2002 | 07:59 AM
VQdriver's Avatar
i use high endurance on my tires. does anyone know if these products cause more harm than good?
Old Sep 2, 2002 | 08:10 AM
PrinzII's Avatar
OG and counting...
The problem with products like Endurance is the silicones that are contained in them. Over time, those protectants draw a greater amount of dirt which leads to the browning. Plus, they are notorious for flinging onto the finish of your car when the tires are rolling.
Old Oct 1, 2002 | 06:37 PM
griffy2k2max's Avatar
Use an old T-Shirt or Towel and just wipe the entire sidewall, I would use an old T-shirt(cheaper). that will take the build up off. I do that every so often and it works, I had the same problem.
Old Oct 1, 2002 | 06:45 PM
hawks25's Avatar
I use the Eagle One Tire Wet and used to get the flinging also. I will wipe the residue off if I'm in a hurry, but I usually leave it on and leave the car sit until most of it has clung to the tire.
I also use a 4:1 mix of Simple Green to wash my tires. If you clean them everytime you wash your car, the residue is not a problem.
Old Oct 1, 2002 | 08:09 PM
NickStam's Avatar
there are better products to use than bleach white
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
