Buzzing When Turned On
Old Sep 4, 2002 | 11:28 AM
melteye's Avatar
When I turn the key to start my car, the engine turns on but there is a slightly loud buzzing noise for about 3-4 seconds. If I turn the key just a little bit and stop before the engine has time to start it gets really loud.
My car didn't do this before, what do you think it could be?
Old Sep 4, 2002 | 12:10 PM
nizmomx's Avatar
that sound is the of 2 things. 1: front the engine mounts or 2 from the intake valve. my car was making that loud ticking noise with it too. Later I found out it was the engine mounts were bad, so they needed to be replaced. If u have warranty, bring it back to the dealership and have them run a test. There was a bulletin about that noise, but not a recall.
-M
Old Sep 4, 2002 | 12:13 PM
melteye's Avatar
It's a electrical buzz... Sounds like a pump. Not an engine noise.
Old Sep 4, 2002 | 12:15 PM
UMD_MaxSE's Avatar
Got Bent?
could it be the fuel pump? When you turn the key to the "ON" position you should hear the fuel pump go on for a few seconds...
Old Sep 4, 2002 | 12:53 PM
melteye's Avatar
Only when its turned all the way...
Old Sep 4, 2002 | 10:13 PM
ABS's Avatar
ABS
Could be the starter relay.
Old Sep 5, 2002 | 12:24 AM
melteye's Avatar
Should I have it checked out or is the buzzing normal.
Old Sep 5, 2002 | 07:58 PM
ABS's Avatar
ABS
Just realized it could also be the anti-lock brake high pressure resevoir pressurizing itself. Most newer cars do this and it is completely normal. It will happen when you turn on the ignition, regardless of whether or not you start the engine.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
salty318
Sep 29, 2015 01:21 PM
