Possible 5th gen tranny swap???
Old Sep 7, 2002 | 02:24 PM
Le1717y's Avatar
is it possible to do a tranny swap with a 5th gen maxima with the VLSD tranny.. is everything the same with the 4th gen trannies as the 5th gen trannies..
Old Sep 7, 2002 | 05:25 PM
Greg's2kGLE's Avatar
Re: Possible 5th gen tranny swap???
Are you asking if you can put a 5th gen tranny in a 4th gen?
Old Sep 8, 2002 | 10:16 AM
Le1717y's Avatar
yea.. is it possible to use the 4th gen tranny on the 5th maximas???
Old Sep 8, 2002 | 11:01 AM
Keven97SE
I haven't heard of anyone who has done this but I don't see why it wouldn't work. The 5th gen 3.0L engine block is the same as the 4th gen, so the bellhousing from either tranny should have the same bolt pattern. The only thing you will have to do is get a new halfshaft/driveshaft for one or both sides. The VLSD trannies have a different transmission housing to accomodate the larger differential. You may also need to replace one or both wheel bearings due to the different driveshafts.
If you find a competent mechanic and are willing to spend an additional $500 or so, you should have no problem installing the 5th gen VLSD tranny. But you would be the first that I'm aware of to do so.
Old Sep 8, 2002 | 12:58 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
5th gen tranny is stronger than 4th gen tranny per DAVEB's (Dave Burnette) research.
I needed to buy both shafts for the VLSD tranny (auto to manual conversion). Bling bling...
Old Sep 8, 2002 | 04:49 PM
Le1717y's Avatar
so overall.. how much do you think this whole auto to manual swap is going to cost.. because i am sick and tired of having an automatic transmission..
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
maxima-junky
Aug 13, 2015 09:59 AM
Supragte
Aug 12, 2015 10:00 PM
