Need a suggestion for FSTB bolts
This problem came up awhile ago where FSTB bolts snap when you try to remove them. I'm talking about the ones that connect the cross beam to the mounting plates. When the first set broke, I replaced them with stainless steel bolts but just today one of those snapped when I went to remove it. Any suggestions on how to prevent this from happening again in the future? Should I be using some kind of anti-seize compound?
Originally posted by BigDogJonx
Not sure what you mean by them snapping. But use some anti-sieze compound
Dixit
Dixit
torque
I didn't measure that but I did use a lock nut. This bolt gives some of the tortional stiffness so I did bear down hard. Is there some number to use for any given bolt?
Re: torque
If you need a spec ,I can find it.
email me>
torque
I thought the 35lbs was for the bolts that hold the spring/strut assembly? The bolts I'm talking about are part of the FSTB and connect the mounting plate (which is held by the bolts you mention) to the tortion rod.
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
RealityCheck
10-02-2015 06:34 PM
DC_Juggernaut
09-28-2015 04:07 PM
