How many have had bad motor mounts?
I did a search on this one and didn't get too many hits on motor mounts. Have you guys been having problems with these at all? I have a 2000 with 70k miles on it, and I'm wondering if I have a bad mount somewhere. If I hold my foot down between 1st and 2nd shift, I get a BAD thud - to me, seems more like motor mount than tranny really. I just haven't had time to even look at it yet.
i went into nissan to have them do the trans TSB and i remarked on how i was hearing a buzzing sound after i turned off the car. they said there was a tsb on the motor mounts and i asked how they could be buzzing and he said they were electronic. he said he would replace them for free even though i had not had any real problems with the motor bucking too far back even though it does more on this car than any others that i have owned/driven. they took around the whole day to do the trans and motor mounts work. if im not mistaken, there are either 3 or 4 motor mounts.
Originally posted by 2000 SE
I have replaced two in the past year.
Originally posted by Matthew
What are symptoms of motor mount damage? How can you diagnose?
a good way to tell excessive engine movement is to pop the hood. put the car in drive. keep you foot on the brake and give it a little rev. you will notice if they are worn out by the movement of the engine. helps to have another person watch the motor for you and know what movement is tolerable and what is excessive.
I know that mine were broken because they happened at the strip. Once they broke you would hear the motor rock back with accel. and forward on braking.
Originally posted by pjalst
Is this a do it yourselfer job , or can an amatuer like me replace them?
Sorry to bring up and old thread, but help me out here.
When driving on the freeway, the car vibrates like mad, especially the steering wheel, when accelerating.
Would this be a bad motor mount? I'm not hearing any clunk noises when I gas it, but I have already tried the following:
4 new tires, mounted and balanced
rims checked out for bends
new passenger side axle
No luck - it just keeps getting worse.....
I noticed when putting it in "D" and hitting the gas and brake, the "front" of the engine does move up about 1 inch.
Anyone else had bad motor mounts and nasty vibration?
Please remember this vibration is ONLY when acellerating....not braking, not cruising.
The Frye
Sep 2, 2021 11:03 AM
