Need Help on connecting amp to Bose sys.
Old Sep 14, 2002 | 10:32 PM
PoweredbyNissan
Can someone help me out with connecting an amplifier to 2k2's stock bose system. I know I can't use the RCA input on the sub. So, I am trying to send the signal to the amp using the speaker level input on the amp. To do that, I need to tap into some speaker wires. I am thinking of tapping into the factory Sub's speaker wires (pre-amp of course, don't want the amp to fry). The problem is I cant figure out which wire is positive and which wire is negative. I see the 6 wires going into the sub through this socket, but I just can't figure out which color is positive and which is negative. I got the power, ground and remote wire hooked up to the amp already. Can someone help me figure out which wire is positeive and which is negative? Thank you in advance, anything helps.
Old Sep 15, 2002 | 04:47 AM
ms.thicknes's Avatar
Re: Need Help on connecting amp to Bose sys.
go to this thread by cobymoby...hopefully this is what you are looking for
http://forums.maxima.org/showthread....highlight=bose
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
