When to Clean throttle body?
Old Sep 16, 2002 | 10:28 PM
BugNout
How often does the throttle body really need to be cleaned if at all? How dirty would it have to be to effect performance? Is there a link to the proper procedure for cleaning?
Old Sep 16, 2002 | 11:52 PM
serin's Avatar
good question. i was wondering that myself actually.
Old Sep 17, 2002 | 01:17 AM
nick778's Avatar
When I had my '99 SE, I would clean it just prior to each oil change and it needed it every time. Now with a 2k3 SE, I plan to do the same thing but have no idea how I am going to clean the extra inner valve that opens at higher rpm. Anyone have any thoughts on this?
Old Sep 17, 2002 | 04:43 AM
UMD_MaxSE's Avatar
Got Bent?
I cleaned mine at 30k.... and it was pretty messy....
Old Sep 17, 2002 | 05:33 AM
njmaxseltd's Avatar
Clean it every time you change or clean your air filter.
Old Sep 17, 2002 | 06:11 AM
SR20DEN's Avatar
VQ Wizard
Whenever you think it looks dirty. If you're bored, have the time and can of spray, do it.
Old Sep 17, 2002 | 07:36 AM
exunaja's Avatar
can someone
walk us through this step or process.
I am a little worry about MAF and many other electronic component in the intake compare to my honduhhh
You can also put them in How to section of this forum.
apreciate it.. thank a bunch
EU
Old Sep 17, 2002 | 08:15 AM
BugNout
Yes the proper TB cleaning process would be nice?
Old Sep 17, 2002 | 08:25 AM
jjs's Avatar
jjs
As would people using the search function...
http://forums.maxima.org/showthread....+body+cleaning
Old Sep 17, 2002 | 08:35 AM
BugNout
I did and read various methods. That is why I was asking for the proper method?
Old Sep 17, 2002 | 08:44 AM
jjs's Avatar
jjs
And what is improper about the ones you have read or the example I provided?
Old Sep 17, 2002 | 08:46 AM
rubman's Avatar
Cleaned mine at 40K. FYI, if you're using Super Unleaded in your Max, as Nissan specifies, it will be clean. When I clened mine, it hardly neede any cleaning. It's a simple procedure, acutally it's simpler on 5th Generations, than on 4th Generations. Do keep in mind, if you do use Super Unleaded(93 Octane), it will rarely need cleaning.
Old Sep 17, 2002 | 11:03 AM
Max2000's Avatar
I just cleaned mine. I have about 39700 on my 2000. I usually put in 93 unleaded... but once in a long while.. I will put in 89s. The throttle body was not too bad. But bad enough that sometime my car will shut down. it took me about 1 hour to finish the job, because I was trying to follow the 4th gen instruction. but realized that I don't need it, 5th gen is easier to do. The can of cleaner cost about 2.99 (forgot what brand is it). Easy job, just few bolt to remove. Result... Very rough starts, that's probably because the left over cleaner in the throttle body, after about 20 sec. Total better.. I drove it for a short while, the 1st gear to 2nd gear is definitly smooooooooooother!, and no more jerking. If you have those sympton, clean it!
Old Sep 17, 2002 | 11:44 AM
Ollie's Avatar
.....anyone have any idea on what spray to use?
Old Sep 17, 2002 | 11:57 AM
UMD_MaxSE's Avatar
Got Bent?
Any throttle body cleaner should be ok... I used Gumout
Old Sep 17, 2002 | 03:00 PM
Max2000's Avatar
don't remember the name... will look it up for you later...
just go to pepboys or something similar, and look at throttle body cleaner...
Old Sep 17, 2002 | 09:56 PM
Max2000's Avatar
the stuff I used is made by Pennsoil (SP??), it's call air intake and throttle body cleaner... pretty good stuff.... like I said.. my car runs like it's brand new!
Old Sep 17, 2002 | 10:42 PM
augie's Avatar
I'll do it when I hit 20k. I am 4k miles away. I think I do that and tranny flush.
Old Sep 18, 2002 | 05:08 AM
SR20DEN's Avatar
VQ Wizard
The most potent cleaner I have ever found id Berryman B12 Chemtool.
http://www.berrymanproducts.com/
This stuff works great for cleaning aluminum engine blocks and parts.
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
97_GXE
Sep 15, 2015 06:47 AM
followthadollar
Sep 13, 2015 09:55 AM
Maxboy23
Sep 9, 2015 10:37 AM
