does the FSTB from streetbeat
Old Dec 19, 2000 | 02:29 AM
Max2000's Avatar
fits 2k max?
thanks
Old Dec 19, 2000 | 06:27 AM
mdeal's Avatar
I've heard it does not, unless you want to cut.
Courtesy just came out with FSTB that is half the price of a Stillen, looks like the Street Beat one, too: http://www.courtesyparts.com
Old Dec 19, 2000 | 08:58 AM
sixman
Yoy have to cut a part of the air box bracket (drivers side) for the StreetBeatCustom FSTB to fit (likewise with the Courtsey). Not really a big deal since enought of the bracket remains to hold the air box.
Old Dec 19, 2000 | 09:21 AM
punkdork's Avatar
Courtesy has released a 5th gen version of their FSTB that doesn't require the bracket to be cut.
dvyuan
Actually you guys are mistaken, if you buy the Courtesy one it no longer requires you to cut anything. I just got mine and it went in without any problems. One question, did you guys keep that metal washer that was on top of the strut tower or did you guys toss it?
Old Dec 19, 2000 | 09:23 AM
punkdork's Avatar
Apparently the instructions with Stillen's FSTB say toss it. Since I had no instructions, mine is still on there. I think I'll remove it sometime soon.
Old Dec 19, 2000 | 12:04 PM
bry2kse's Avatar
I took my original washer off as the connecting piece on the Stillen performed the same function, and actually had a larger surface area to contact the chassis.
Love my TSB. =]
Old Dec 19, 2000 | 07:48 PM
PRINCE NISMO
dvyuan I also have a Courtesy Bar, installed it this weekend and I left the washer on the strut towers since the Bar went on without any problems or mods needed. I think its just a personal choice. When using this brand.
Old Dec 19, 2000 | 08:15 PM
mdeal's Avatar
PRINCE NISMO,
Are you saying you installed the 2k-2k1 version, or the '99 version, this weekend?
I ordered one from Courtesy, today, and am looking forward to the install in a few days. Any tips appreciated for anything out of the ordinary for the 2k-2k1 install.
Old Dec 19, 2000 | 08:37 PM
guchi's Avatar
I just purchased the Courtesy bar last week and installed it with now problem...even left on those top washers (not sure why) but wtf just left on since it all fit and the hood close ok.
I do have a problem with the driver side windshield squirter. It doesn't work now, only the passenger side does. Look into it and found that the bar is pushing up against the inside hood baffle and squishing the tube.
Just my 2cents....
laters
Old Dec 19, 2000 | 09:12 PM
PRINCE NISMO
Originally posted by mdeal
PRINCE NISMO,
Mdeal,
The version I have is the 2k-2k1. The End plates fit around (over) the whole strut tower not like the '99 version which only covered 2/3 of the tower. I did noticed on the passenger side I had to put a little push to get the plate on but no cutting or alterations needed. I went 9 turns (notches) on the bar at each side (once again I think it's a personal choice there is nothing in the directions on how many turns). And I used a torque wrench set at 35lbs to bolt the end plate to the strut tower. Also don't throw out the plastic bag the Bar comes in for some reason Courtesy put their instructions on the Bag. Good Luck and enjoy..... As for me I feel it was a good investment.
[Edited by PRINCE NISMO on 12-19-2000 at 11:17 PM]
Old Dec 19, 2000 | 09:26 PM
PRINCE NISMO
Just my 2cents....
laters
I just checked mine and they both seem to be working normal.
Old Dec 19, 2000 | 10:29 PM
punkdork's Avatar
My washers work fine and I still have the extra plates on.. but I'll be removing them soon.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
2000MaximaSE
Dec 12, 2000 10:35 PM
OgreDave
Nov 21, 2000 12:47 PM
josh95se
Oct 14, 2000 05:39 AM
