Double sided adhesive..
has anyone had success removing any part of the body (not just emblems) that uses this stuff (whether or not other clips or fasteners are involved)? What was the technique?
This is specifically directed at DIY'ers, not taking the car to a shop.
Thanks!
Thanks!
Re: Double sided adhesive..
Thanks!
Thanks!
Re: Re: Double sided adhesive..
Originally posted by ms.thicknes
what adhesive I could not get off with my fingers.....I clay-barred off
It is fairly hard to do the side door gaurd since you dont want to use a screwdriver to dent the door itself. It was meant more for when the car got into an accident and it was probably half off and they can replace it from there easily.
Dixit
A heat gun usually works very well for adhesives. It wouldn't hurt to try, just don't turn it up too high or leave it on one spot too long. I imagine it could get hot enough to cause damage if used improperly.
Good luck, hope it helps some.
Thanks!
Thanks!
I used it with fishing line but in your case you might want to use the line where you can and lots of goo gone to keep it from readhearing. Then soak the areas you can't use line on and start prying it off. Alcohol may help but be sure to use the goo gone once it has seperated because the alcohol will make the adhesive real sticky. Also try calling a body shop and see if they have any pointers.
Hope this helps.
Hope this helps.
Andy29
Sep 29, 2015 05:32 AM
BrandonCause
Sep 14, 2015 10:41 PM
