Mom's Catalytic Coverter is stuffed up?????
Old Sep 20, 2002 | 07:30 AM
Ramius83
As many of you know, I have a 4th Gen and my mother has a 5th Gen. Well, needless to say, I went to drive it the other day and the Service Engine Light came on. So knowing that Nissan gipped you guys and you can't check your own ECU codes, I took it to Autozone to get their free diagnostic service. It brought up the catalytic coverter code. What does this mean? Is it "broken", backed up, wire loose? I know nothing of her 5th Gen and any help is greatly appreciated. Thank guys.......
Old Sep 20, 2002 | 10:14 AM
Y2KSESteve's Avatar
Re: Mom's Catalytic Coverter is stuffed up?????
You could take it off and look at it. If needed put a replacement on. Other than that, take it somewhere and have it looked at.
Old Sep 21, 2002 | 11:59 AM
ABS's Avatar
ABS
If there is an O2 sensor after the cat, then it probably means that the trailing O2 sensor got a reading similar to the leading (before the cat O2 sensor. The reading should be different (less oxygen after the converter than before. This could be caused by either a bad cat converter or a bad O2 sensor or even a wiring issue . . . How many miles are on the car? Catalytic converters usually last a really long time.
Old Sep 21, 2002 | 03:40 PM
Ramius83
The car is a 2000 model and only has 41k on it. I am gonna take a long look at on it Monday/Tuesday. Thanks to all who responded.
Old Sep 22, 2002 | 09:55 AM
ABS's Avatar
ABS
I doubt it's the converter then . . . probably just a bad O2 sensor. Big price difference between those parts as well.
AboveDaCloudz
Oct 8, 2015 11:25 PM
09maxshawn11
Sep 30, 2015 10:28 AM
DayHeyZeus
Sep 11, 2015 03:17 PM
carid
Sep 9, 2015 05:06 AM
Justin Kroll
Sep 2, 2015 11:06 AM
