Put my UDP on today!!!
Old Sep 21, 2002 | 05:07 PM
hawkdog's Avatar
I just got mine on today!! It really wasn't that bad of an install...especially considering all the horror stories I've heard. It took me about 3 hours and I broke a 1/2 ---> 3/8 socket converter, but other than that it was a piece of cake. Just make sure you've got a good long breaker bar (at least 18") and a set of socket "elbows" or whatever they are called. (the things that let you bend corners with a socket wrench). There is no way you will get it done without those. One tip I have is when you have to loosen the 14mm bolt on the back of the PS pump, reach around the control arm with your right hand, and hold the head of the socket onto the bolt while you turn it with an "elbow" on the socket wrench. That bolt is definitely the worst part of the whole install. I used the "crank the motor" method to break the crank bolt loose. It worked very well....thanks for all the tips guys.
Now, the important part...it definitely revs up faster, and I think it pulls on the top end even harder now. I definitely feel a difference!! It's not huge like the y-pipe, but it was worth the time and $$!!!
Old Sep 21, 2002 | 08:14 PM
hawkdog's Avatar
just got back
I took it out for it's first real drive tonight....I am WAY impressed. I SPANKED a mustang 5.0. It was modded and everything too. I've beaten them before, but never like that. It was sweeeeeeeeeeeeet.
Old Sep 21, 2002 | 08:26 PM
Tanman's Avatar
Re: just got back
Congrats on the purchase and install. Hopefully you don't have the problems others have had. You know, you'll have to remove it when you get an SC .
Old Sep 21, 2002 | 09:24 PM
asu174's Avatar
Clay Aiken has fancy genitals
I'm reattempting my install with 2k2_6spd tomorrow morning. That will be the last available bolt on mod I can do, so after that I am pretty much done other than cosmetic and stereo stuff.
I'll post how it goes tomorrow.....
Old Sep 21, 2002 | 10:28 PM
2001SE's Avatar
you're not out of options man.....you still got boost
Old Sep 22, 2002 | 09:25 AM
DrVolkl's Avatar
Yeah, let us know. The UDP is one of my favorite mods. Had em on my 85 stang, and 98 GSR. Both times it improved my 1/4 mile times by about .2 secs. Real sweet stuff. The unorthodox racing ones are nice too..they do a good job. I was just scared because the maxima is a pretty tight fit!
Old Sep 22, 2002 | 10:12 AM
Tanman's Avatar
I second that vote, SC's are bolt-on too .
Old Sep 22, 2002 | 03:32 PM
asu174's Avatar
All done with the install on mine. The hardest part that the had was with the tensioner on the poer steering belt. It took a total of 2 hours to complete the job.
I think that I can already feel a difference. It feels stronge off the line. That might be because we added in a bunch of air to the tires. I was down to 26 psi on all 4. Beefed it up to 45 psi. That might have helped quite a bit.
Okay, I'm done with performance mods. On to other stuff now......
jc53
Oct 6, 2015 06:00 AM
carid
Sep 9, 2015 05:06 AM
nbstriker10
Sep 4, 2015 04:26 PM
crazyespn
Sep 3, 2015 01:30 PM
Justin Kroll
Sep 2, 2015 11:06 AM
