Engine Knock at Startup
I had an alarming experience this evening with my 2K2 GLE and I want to see if anybody else has experienced this. My car sat for four days without running. I went to start it this evening and I heard a clacking sounc coming from the engine bay. It reminded me of the sound an engine makes when it has just been completely drained of oil for an oil change, refilled, and then started. I've never had this happen with an engine just because it sat for several days. This motor has less than 7K on it. I was in an enclosed area which might have amplified the sound, but I've never had this happen with my other cars. Has anybody else had this happen? I swear I heard some ticking after the clacking stopped. The ticking seems to be gone now. I think I might take it to the dealer just to have this documented. Similar experiences out there?
actually, yes... several 2k2-ers have had this. Dont be alarmed. Its actually the timing chain.
The older 3.0 Vq's would do it, but something about the new 3.5 design makes it more susceptable. I would certainly call the dealer and gripe. Noise like that cant be good for the timing chain, but in reality its likely to not be/cause a problem based on what others have found and mentioned here. Nonetheless, I think Nissan should look into a fix for the oiling mechanism for chain.
Thanks for the feedback. I suppose I should feel a bit better because of this response. I can't seem to find any other threads on this subject -- I wonder how many people have noticed this after letting their 2K2 Max sit for several days.....
I'm still keeping my ears open!
its been mentioned several times. I'm not sure what the keywords would be for a seach.. probably 'clatter'
http://forums.maxima.org/showthread....hlight=clatter
Hey, had the same thing happen to me at about 600 miles. Here's a link to a discussion on freshalloy after I posted there (I'm knot240 over there).
I've got over 6,000 miles now with no recurrence. I don't think it's anything to worry about.
Yup, me too...this has happened twice only in 2 years, and it is usually after prolonged sitting...more than 2 or 3 days. The weird thing is that it doesnt do it every time I let her sit for a few days tho
When she sits overnight only it never does it.
I used to have it happen in my 4th gen I-30, but not yet in my 5th gen 2002. It seemed to happen when I got cheap and used a regular 20w-50 oil, but whenever I had synthetic oil in it, including now, it hasn't re-occured.
I've encountered the same thing after letting the car sit right after a long trip. Has anyone encountered any lifter problems at cold startup? I get a ticking noise every now and then that goes away after a couple of min. I've never raced the engine when cold.
chain tensioner is oil driven. perhaps it has more to do with what filter you are using and if it has a check valve (or if the check valve is working). once you have oil pressure and the chain gets re-oiled, the sound will cease.
Syn could possibly affect your oil pressure, but weight would have more of an effect.
Same observation. I have noticed engine clatter upon startup for a few seconds after my max sat for about three days. I only noticed it once. That's the only time my max sat still for that long. 2002 SE - 3000 miles
TimW,
Great thinking man. I totally forgot to mention that I talked to some dealerships about that one - I was using the Mobil 1 filter w/ 5w30. I switched over to the Nissan filter after talking to some of the service guys. Evidently the Nissan filters do have a check valve that actually holds some oil in the engine, not just in the filter. Changing the filter seemed to help, but I still get it every now and then.
So is it that bad to let you car sit for a couple of days without starting it. My car sits in the garage from 3-5 days without getting started all the time since I use a company car for work. I only get that clatter noise right after I change my oil. I always almost get an oil light that flashes a couple times at start-up though. Is that normal?
Mine is like a squealing type noise. Happens after a few days of sitting and especially when its cold in the morning.
Im taking my car Monday to get the friggin guage cluster replaced because of that stupid faintly lit "check engine" light being on.
Is there anything I suggest they do to get rid of this noise or should I just leave well enough alone???
Originally posted by 2K2SE
Sounds more like a belt slipping. Dunno how many miles you have, but even a new belt could sound like this if it isn't properly tensioned. Ask the dealer to check.
My 2k2 has about 6500 miles on it, I'll ask them to investigate...
ballerchris510
Sep 11, 2015 05:29 PM
