Experience with Injen Cai @ High Speeds vs PR Hybrid Apexi Setup
Old Sep 26, 2002 | 06:38 AM
PCGuRu2K's Avatar
My previous setup was the upper PR tube from the cai attached to a Apexi filter. With this setup I was able to go well past 130+ and it will still pull. Now that I've driven with the Injen Cai setup for about 2K+ miles, I'm sure that has been enough time for the ecu to learn. I noticed that there is a bog once I hit 120mph. And it's take forever to climb up. I guess this is because of the piping of the Injen? Since it's longer it can't suck the air as hard as a hybrid setup would at high speeds/rpms..
Does anyone else think the same?
Old Sep 26, 2002 | 07:02 AM
soundmike's Avatar
Very sound, Mike
Yep it's possible, the path of air is longer this time around and that long pipe acts as a hindrance. It's like sucking air through a straw.
This is why a lot of people say HAI/Hybrid for better top-end while a CAI is for better low-end grunt.
Old Sep 26, 2002 | 07:15 AM
Bags's Avatar
VG Ridah's Biatch Hoe
if you look in the track forum there is alot of talk about this.
I just switched from my PR CAI to Hybrid to see what the differences are.
I have only been on the HAI for 2 days
BTW soundmike, I am NOT stalking you
Old Sep 26, 2002 | 07:26 AM
soundmike's Avatar
Very sound, Mike
It never ocurred to me, but now that you mention it
Old Sep 26, 2002 | 08:05 AM
Bags's Avatar
Old Sep 26, 2002 | 09:50 AM
ToYLeT902's Avatar
JET Speed Lab
Old Sep 26, 2002 | 10:04 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Re: Experience with Injen Cai @ High Speeds vs PR Hybrid Apexi Setup
Do you have the Apexi filter on the INJEN? If so, does it fit perfectly? Thanks.
!!!WE NEED TO HAVE AN INTAKE DYNO SHOOTOUT!!!
Old Sep 26, 2002 | 10:10 AM
stose95's Avatar
How about the size of the filter?
What if you put a bigger filter on the injen?
That should suck more air at high end.
Old Sep 26, 2002 | 10:52 AM
IceY2K1's Avatar
Re: How about the size of the filter?
I've read of 400+whp turbocharged IS300s using the same filter, so I doubt it's the filter.
It's the tubing size/length or it's all in his head.
Old Sep 26, 2002 | 11:26 AM
maximadave's Avatar
detailerdaveb@gmail.com
I noticed it too as soon as I hit 120 mph and had no more top end
I was going against a Lexus GS300
Old Sep 26, 2002 | 02:28 PM
IceY2K1's Avatar
Where are you at in your RPMs?
If it's truely restrictive, you will hit the same "dead spot" in ANY gear at the same RPMs. However, it's probably more noticeable in 5th gear(6th gear?).
Old Sep 26, 2002 | 04:31 PM
maximadave's Avatar
I don't remember where my rpms were. I was in 6th gear at 120, maybe next time I'll downshift.
Old Sep 26, 2002 | 04:36 PM
soundmike's Avatar
Very sound, Mike
Dave check your email
Old Sep 26, 2002 | 04:55 PM
maximadave's Avatar
mike, check your email
Old Sep 26, 2002 | 05:27 PM
djPlayboy's Avatar
wont a 6spd car go faster in 5th rather than in 6th.... i may just be thinking off my head but i do remember reading somthing about the 6spd mustang cobraR top speed was 158 in 5th gear....
Old Sep 26, 2002 | 07:59 PM
KLOOGY's Avatar
L33t BMW Drivah
I know a lot of you CAI lovers wil flame me, but at high speeds I think a Frankencar, or Full Berk intake will be superior. There is so much air rushing into the motor, your CAI is useless. All those bends in it cause a restriction of airflow. This makes the straight design of the Berk and Frankencar superior and more effective at highway speeds...... I have driven several Maximas with CAI's....
Old Sep 26, 2002 | 08:47 PM
Dany's Avatar
I agree as well, at high speeds my car pulls like crazy.
Old Sep 26, 2002 | 09:46 PM
taylrr's Avatar
I have a CAI on my 2k2 6 speed and I didn't have too much problem at high speeds. I won't go into the scientifics of which is better because I'm a college dropoutand wouldn't know, but I was going 140, and I still had some pull I was just running out of road. You do have to stay in 5th gear as it has a better ratio than 6th does for that kind of driveing. I wouldn't give up the low end for anything, my favorite is playing with a probe or cavalier, cruising with him in second gear until I hit 4-5000 rpm's then just taking off and letting him check out my painted rear sway bar.
Anyone out there run a 6 speed 2k2 without CAI, what kind of top speeds are you hitting? I'd probably switch back to non-CAI just to hit a new top speed.
Robert
Old Sep 27, 2002 | 06:57 AM
stose95's Avatar
I still have a feeling if you use the same size filter as the berk or franken, the injen will pull
like those intakes at high speeds.
Thats what I plan on doing once I get the injen, I will let you guys know
Old Sep 27, 2002 | 07:09 AM
PCGuRu2K's Avatar
Their all cone filters in essence.. I think it's really the long tubing of the Injen that hurts our topend...
Old Sep 27, 2002 | 07:16 AM
soundmike's Avatar
Very sound, Mike
It's simple physics and yes it is the long tube.
Again think of a straw, get a really long one and a big bottle of soda or something. All the while, time yourself and the volume of liquid you can move in xx seconds.
Now try sucking slowly, no problem right? Now try sucking a little harder. There's a threshold as to how fast you can suck the soda from the bottle into your mouth. Sooner or later you'll feel the pressure in your head. Why? Because you're trying so hard yet only so much soda is going up the tube.
Now do the same experiment using 1/3 the length of the straw. You'll be able to move much more volume that way with less the effort.
Old Sep 27, 2002 | 07:24 AM
BlackMax2k1's Avatar
I don't really care cause I don't drive 120-140 mph anyways! Where are you guys driving the Salt Flats?
Old Sep 27, 2002 | 07:27 AM
soundmike's Avatar
Very sound, Mike
Incidentally enough, i never thought i'd reach 120mph in normal highways.
But the Max accelerates pretty fast that when i'm going 80 (highway speeds) and need to overtake someone 120 can come pretty quickly.
Old Sep 27, 2002 | 08:01 AM
stose95's Avatar
I understand what youre saying, but then there is the element of the opening at the end of these tubes. A bigger filter naturaly will allow more air to be sucked in.
So what Im saying is a longer bent tube will restrict flow but so will the size of the filter. Put larger filter instead of the 3" that comes with the injen and you should be pulling a little harder at high end.
Old Sep 27, 2002 | 08:37 AM
PCGuRu2K's Avatar
Originally posted by BlackMax2k1
I don't really car cause I don't drive 120-140 mph anyways! Where are you guys driving the Salt Flats?
I hit 120 everyday I goto work in the morning on I95... That's why I love driving in early in the morning..
Old Sep 27, 2002 | 08:44 AM
Max_Vader_2K's Avatar
Well hells bells
I will stick with my Stillen Intake if this is the case... . . . . .
Old Sep 27, 2002 | 10:17 AM
soundmike's Avatar
Very sound, Mike
That's true, but comparing a CAI and HAI with the same filter you'll still get better response on the higher rpm band with the HAI.
Old Sep 27, 2002 | 10:34 AM
SkyDaver's Avatar
Ohh, any side street.
If you recognize the source of that line, PM me ;-)
Old Sep 27, 2002 | 10:36 AM
maximadriven's Avatar
Are you looking to sell the PR/Apexi setup?
Old Sep 27, 2002 | 12:55 PM
PCGuRu2K's Avatar
Re: Re: Experience with Injen Cai @ High Speeds vs PR Hybrid Apexi Setup
I actually plan on putting back in the PR/Apexi HAI Hybrid.. So I'm probably gonna sell the Injen.. Anyone interested?
Old Sep 27, 2002 | 01:01 PM
PCGuRu2K's Avatar
Old Sep 27, 2002 | 01:55 PM
PCGuRu2K's Avatar
Old Sep 27, 2002 | 03:53 PM
PM me a price. I have a 2000 SE.
Old Sep 27, 2002 | 08:06 PM
KLOOGY's Avatar
L33t BMW Drivah
Re: Well hells bells
Notice how I have stuck with my Franken - Berk Combo... I refuse to pay $300 for a BS CAI !
BTW, Soundmike has the exact concept. If you look at most sports cars with excellent intakes, Camaro SS etc... they feed the air DIRECTLY into the upper intake. No one uses excessive bends , because , while that might give you a colder air source, it also creates a longer path , to suck the air THROUGH.... Buy what you think is best for you. Just dont overpay for an useless mod...
I<3 A32's
Sep 10, 2015 11:07 AM
Max139617
Sep 6, 2015 06:02 PM
jfl330
Sep 4, 2015 01:44 PM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
