Oil pressure light blinking!
Old Sep 27, 2002 | 02:10 PM
warrlocked's Avatar
I have noticed that my oil light will go off after the bulb check while starting the car. Then, it will come on and blink 1-3 times very quickly. It's not doing this EVERY time while starting..only sometimes. Sometimes it will do it (at start-up) even if the car has only been sitting for a few minutes and started again. Very random.
I had my transmission serviced and an oil change a week ago at a Nissan dealer. I didn't tell them about the oil light until I went out to my car and started it..and it blinks! I went back in and got the tech to come see it for himself. It then blinked at start-up again while he was watching. We got the keys to another 2K Max on the lot and started it to see what it would do....it did not blink.
I didn't have time to have them check it out. I doubt that it is anything serious...maybe just the oil sending unit...which probably wouldn't be covered under warranty. I am about to turn over 39K. Anyone else notice this on their Max?
Old Sep 27, 2002 | 02:15 PM
spaaz14's Avatar
Ditto......mines been doing that for 2-3 months.....only immediate startup
Old Sep 27, 2002 | 02:26 PM
warrlocked's Avatar
How many miles do you have on your 2K?
Old Sep 27, 2002 | 03:26 PM
TimW's Avatar
The silent but deadly Moderator
Mines been doing that since 14K. its just a blip at start up. Its not multiple blinks.. that would concern me. Many have commented about the blip. Its pretty common. Seems like its been there since I went to mobil1 5w-30
Old Sep 27, 2002 | 04:11 PM
Green 2kSE's Avatar
I've had exactly the same experience, it blinks once at startup and then it's off. I've been using Nissan oil filters with Mobil1 5w-30 but will experiment with other filters and oil to see if I can get rid of it. Perhaps we can run a poll to see what other people are using if they also get blinks?
Old Sep 27, 2002 | 06:31 PM
pinakbet's Avatar
Using Nissan filter w/ 10w30 Mobil1... getting the same thing. I turn the key, blink....start.... blinkblink...
Old Sep 27, 2002 | 09:31 PM
Fezzik's Avatar
Same thing happen here. Just at random times
Old Nov 12, 2002 | 05:48 AM
pinakbet's Avatar
time to resurrect this thread from the dead...
I'm guilty of doing the ground wires modification. . . The one thing that i really and truly noticed from doing this modification is that the oil pressure light that used to blinkity-blink on startup is no longer doing that.
I'll leave this for you to speculate... It's just my observations. I'll disconnect the ground wires and see what happens on startup.
kden,
bryan
Old Nov 12, 2002 | 06:19 AM
Tanman's Avatar
Same thing here, but seems to occur intermittently with oil changes. I'm using Amsoil 10W-30 6-month change interval. Since the last oil change a month ago, the oil pressure light doesn't blink at start up. Coincidently, I only put in 3.75 quarts this change. Last change I put in 4.25 quarts and got the blinking oil pressure light. Of course, I have an SC which makes the oil flow path longer, so maybe that's the cause of mine? .
Old Jan 11, 2003 | 08:55 PM
Green 2kSE's Avatar
As a follow-up, I changed the oil from Mobil1 to Castrol GTX 5W30 and the oil blinking at startup is now gone. I'm thinking that Mobil1 is so thin at startup that oil pressure doesn't build up quickly enough.
Old Jan 11, 2003 | 11:17 PM
KennyLau's Avatar
Re: Oil pressure light blinking!
I have always used Castrol GTX 5W-30 oil and Nissan filters. I haven't experienced that problem yet. I'm closing in on 52K miles.
It could be the oil you were using.
Old Jan 12, 2003 | 09:00 AM
Tanman's Avatar
Re: Re: Oil pressure light blinking!
Maybe add a 1/4 or 1/2 qt more oil? Mine stopped doing it after the last oil change, and I might have added more than usual.
Roymg
Sep 3, 2018 05:10 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 13, 2015 12:50 AM
