question about high speed handling
hi guys,
i just purchased my 2000 gle a couple of weeks ago and it rides great, the only thing i have noticed is that at high speeds between
65-85 the car feels a little to loose or uncontrolable, especially when i change lanes. It is kind of scary sometimes....
is this normal?
if not how can i fix it?
i have stock 16 in rims and the tires are almost bald, could that be it?
do i need 17in rims?
any advice would be appreciated!
thanks
is this normal?
thanks
Re: question about high speed handling
Originally posted by cyberg21
hi guys,
is this normal?
thanks
hi guys,
is this normal?
thanks
You should get a front strut tower brace, that'll help the car at high speeds
hi guys,
is this normal?
thanks
hi guys,
is this normal?
thanks
Mike.
Might want to check struts. If they are original, then they probably should be changed. Also, the FSTB and RSB will help. If you are interested in a firmer ride you could aftermarket springs. This would give you more controlled ride. If springs and struts are done at same time, it saves some labor. Search will give info on struts and springs. Have fun.
Originally posted by vizslak7
Definitely FSTB and RSB. You will be happy with your high speed handling.
JS
JS
Originally posted by roastduck88
Front strut bar and rear sway bar will NOT help you when you are driving at high speeds. They will only help you when you are taking a corner at high speed. If you change your struts and springs you will notice a drastic difference in your ride at high speeds. You will feel like you have more controll. The only downfall is when your car's ride will be more firm and you will feel pot holes a bit more. I would suggest you get adjustable struts. That way you can find the level of stiffness you are the most comfortable with.
John
Yeah, that's what I was thinking. The culprit would be the soft GLE suspension. Change the springs and struts.
DW
DW
Originally posted by MetaOrbit
I don't agree with that. My car, with just a FSTB feels a lot more stable at high speeds during simple things such as lane changes, versus my dad's I35 without it.
John
John
sdotcarter
09-02-2015 09:53 PM
Justin Kroll
09-02-2015 11:06 AM
MaximaDrvr
08-19-2015 08:20 PM
