H&R install: Need help
Old Oct 3, 2002 | 01:33 PM
VQMaster's Avatar
For those who have done a self install:
What tools are needed
How much time
Level of difficulty
Advice is greatly appreciated.
Old Oct 3, 2002 | 02:00 PM
Cutler's Avatar
Re: H&R install: Need help
How much time
Level of difficulty
4-6 hours
Spring compressors
Air tools if you have them
breaker bar
deep socket set
Torque wrench
and plenty of patience
best of luck!!!!
Old Oct 3, 2002 | 02:03 PM
Sly's Avatar
Sly
Tools:
Spring compressors
Torque wrench
set of wrenches
set or sockets and a ratchet
Time:
Depends on number of helpers, but probably half a day if you take your time.
Difficulty:
Easy to Moderate. A competent DIYer should have no trouble. A beginner should ask for help.
Old Oct 3, 2002 | 02:15 PM
TellschMax02's Avatar
I would not want to do the shocks/springs alone, so grab a buddy (makes it a ton easier).
Make sure you have the right tools and it will be a snap. You will need a socket set (extensions, universal joint, etc..), a breaker bar, torque wrench, and a strut style spring compressor. The rear is the trickiest but I found that if you use a deep well, extension, and a universal joint - you should have no problem getting the bolts out/in. I was also able to get my torque wrench on top of that setup to accurately torque all of the nuts.
Air tools will make the job go by a little quicker, but not a must have.
Brian
Old Oct 3, 2002 | 03:20 PM
VQMaster's Avatar
What size tools should I use? Since I don't have tools I will have to rent them.
Old Oct 3, 2002 | 03:37 PM
Click Me!! and scroll down to the bottom.
MaximaDrvr
Aug 19, 2015 08:20 PM
MOHFpro90
Jan 14, 2011 05:05 PM
Vyrus
Aug 4, 2002 09:08 PM
