Creaking noise from front.......?
Old Dec 21, 2000 | 01:54 PM
kpark's Avatar
Whenever I pull out I hear a creaking/tapping noise from the front left of my car. I've read earlier similiar posts and had the front left strut replaced. But I still get that annoying sound. The dealer can't find anything wrong even after 3 visits. I don't see any lubricant on my rims so it can't be a ripped CV boot. Anyone else have this problem?
Old Dec 21, 2000 | 02:00 PM
Weasel's Avatar
Do you mean when you're making a tight turn? If so, it's probably a CV problem.
Old Dec 21, 2000 | 02:05 PM
Dany's Avatar
I had the same problem, only my problem was on the right side
the creacking noise is not because of the Strut, it is the Strut Mount, it has that rubber bushing on it and it rips and causes that creacking sound. My dealer replaced Strut Mount and it went away.
kpark's Avatar
I always hear the noise in the first few feet of driving even after I've straightened out the wheel to move forward.
Old Dec 21, 2000 | 03:35 PM
areX's Avatar
same here
hey, i've been noticing the same thing in my car. so when i go to the dealer, what exactly should i say so that i don't sound so much like a fool when i go in there?
thanks for this post, btw.
Old Dec 22, 2000 | 06:16 AM
sentient
I wonder if...
... it has anything to do with the ABS self-test. The manual says you may hear a mechanical noise when you first drive the car, and it's a normal self-test procedure for the ABS. In fact, my old car's manual said that too and I never heard it, until one recent day it happened regularly, but then the ABS light went on and found out I had a bad speed sensor.
Old Dec 22, 2000 | 08:38 AM
kpark's Avatar
If it was the ABS wouldn't I hear the sound after I start the engine, not when I start moving? Also (correction) it is the right side not the left. Wouldn't the dealer replace the strut mount also when replacing the strut itself? Man my car has too many problems
Old Dec 22, 2000 | 09:37 AM
tomz17's Avatar
Nope.. the abs conducts ANOTHER test once you reach a certain amount of mph... i dunno how much.. it's in the manual... or possibly someone else on this board could tell you..
Old Dec 24, 2000 | 11:04 PM
xydavid's Avatar
you'll hear another noise when you start moving in gear. I usually hear it when backing up out of my driveway. That noise is normal and is less than a second. The noise is hard to explain, but it's quick. My Sentra with ABS used to do the same thing so I'm used to it, but it is alarming to hear until you realize what it is.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
