Changed Trans fluid...Need help
Old Oct 8, 2002 | 07:19 PM
gt350mike's Avatar
I just changed my trans fluid in my 01 tonight and I'm a little concerned on a few things. First, when I dropped the pan I found a layer of "stuff" about 1/8 thick on the magnets that are inside the pan. Should I be worried about this or is it normal?
Second, I put in 4 quarts and and the fluid level checked out fine when it was cold. I took it out for a 10 mile run to the store and I noticed that the trans slipped on me twice. Stupid question, should I put in 4.5 qts? It seems that 4 quarts wasn't enough.
I've researched this subject and I've seen opinions vary from 3 qts to 4.5 qts.
FYI - I didn't measure the amount of fluid that came out because I HAD A BRAIN CRAMP.
Need help on both of these!
Old Oct 8, 2002 | 07:34 PM
Virus's Avatar
A complete flush which is the only way that your going to truly change your transmission fluid it takes around 10-11 quarts.
Old Oct 8, 2002 | 07:49 PM
GimmeTorq's Avatar
Re: Changed Trans fluid...Need help
As far as I know, you need to measure the AT fluid level at operating temperature with the engine running. Only then you'll get an accurate reading. I believe the correct procedure is included in the user manual. Both underfilling and overfilling the tranny are bad news and will cause problems.
doctorpullit
Jul 20, 2019 09:31 PM
spencerwh1
Jun 30, 2016 05:44 AM
carlosvq30
Sep 26, 2015 09:44 AM
f.matejaiii
Sep 21, 2015 12:09 PM
RWCreative
Sep 21, 2015 11:01 AM
