RPM Monitor On APexi RSM Is Frozen??
Old Oct 9, 2002 | 06:01 AM
PCGuRu2K's Avatar
Well I started up my call this morning. The RSM turned out an usualy. But the RPM on the monitor stayed at 2371?? Did not even fluctuate. It seemed frozen. But the Speed was working fine. Do I have a loose wire or something? Did a setting get locked?
Old Oct 9, 2002 | 06:20 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Maybe the RPM wire fell off.
Old Oct 9, 2002 | 06:48 AM
silverkorn's Avatar
if thats the case shouldnt it be stuck at 0?
if its stuck on one number then its reading a fixed voltage which means it could be hitting something else?
Old Oct 9, 2002 | 06:50 AM
Y2KevSE's Avatar
Accidentally grounding?
Old Oct 9, 2002 | 08:30 AM
Bags's Avatar
VG Ridah's Biatch Hoe
yeah I would check for a short where you tapped into to get the RPM signal and all the connections from there to the RSM
Old Oct 9, 2002 | 09:00 AM
PCGuRu2K's Avatar
Hopefully it's just a ground short or loose cable.. I'll have Jeff check it out this weekend when he's doing my stillen kit..
Thanks!
Old Oct 9, 2002 | 09:59 AM
silverkorn's Avatar
i think that would make it go back to 0 again
i think there is a loose wire somewhere and they are touching.
PCGuRu2K, did anything happen when you started noticing this, or was it just one time you started up the car and you saw it doing this.
Old Oct 9, 2002 | 10:06 AM
Y2KevSE's Avatar
The only wire that reads the ECU RPMs is the RPM wire from the RSM. If it's loose it should flutter and/or go to 0 since the voltage will be distorted.
Old Oct 9, 2002 | 10:36 AM
silverkorn's Avatar
yea see thats what im thinking, but its reading voltage from somewhere in order to read over 2k RPM's
it dun make no sense
Old Oct 9, 2002 | 10:53 AM
20006spd's Avatar
i had the same problema and fixed it!
all you have to do is move the directional arrow down and it will erase the frozen setting. the same thing happened to my rsm on my camry.it froze, so i did research and someone told me to mess around with the arrows while in the monitor Rpm mode.
hope this helps, it is NOT a bad connection if its the same thing that happened to me. it will erase itself an go back to 0 just mess around with the directional arrows.
Old Oct 9, 2002 | 11:06 AM
Y2KevSE's Avatar
Re: i had the same problema and fixed it!
This would make perfect sense if his other readings weren't working correctly. The RSM does have a peak hold.
Old Oct 9, 2002 | 05:46 PM
PCGuRu2K's Avatar
But my speed, and l/r settings are 0. The RPM is the only one locked at like 2226.. It's not bold or anything. Will that arrow thing still work?
Old Oct 9, 2002 | 06:52 PM
silverkorn's Avatar
Re: Re: i had the same problema and fixed it!
i thought it only holds the highest RPM recorded. so once he revs past that then it will change to the new highest, at least thats how my friends SAFC worked. if i remember correctly its the down arrow, the up arrow shows the highest and the left or right, dont remember, will reset the highest recorded valve. with the SAFC the highest valve is shown with a solid color behind the value, kinda like a bold.
try messing with the arrows and see if it helps.
Old Oct 9, 2002 | 07:26 PM
MiniRX7's Avatar
WHEN THE HELL DID APEXI MAKE A REAR STRUT MOUNT FOR US..
How does your car handle with the APEXI RSM? Is it a rear strut mount with pillows/??
ED
aw11power
Oct 10, 2021 04:57 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
