Helppppppppp! Window problem...
Old Oct 10, 2002 | 09:03 AM
cyberg21's Avatar
i need help
my 2k driver side window makes a horrible screech (like scratching a chalk board) when i put up or down, I tried cleaning it with windex, and with a razor blade, I wet the glass on the inside and outside with water to moisten or lube it.....NO LUCK!
the noise is killing me!!!
any ideas or tips would be appreciated!!!
thanks guys
Old Oct 10, 2002 | 09:04 AM
jjs's Avatar
jjs
Re: Helppppppppp! Window problem...
Originally posted by cyberg21
i need help
thanks guys
is it tinted?
Old Oct 10, 2002 | 09:35 AM
TimW's Avatar
The silent but deadly Moderator
napa/pepboys.. they have a lubricant for the window channel.. just dont get it on your paint or interior (spray with a rag over the tip to block drips and overspray)
Old Oct 10, 2002 | 10:18 AM
njmaxseltd's Avatar
He's probably got a pebble stuck in the channel. Thats makes a horrable screach when it scratches up the against the side of the glass.
Old Oct 10, 2002 | 10:24 AM
Larrio's Avatar
The Definitive AE Master
i took mine to the dealer, I thought they would give me problems about the tint... but instead they replaced the window runners and lubed/greased up the window and the problem went away. good luck
Old Oct 10, 2002 | 09:51 PM
Wasim521's Avatar
Both my driver's side and passenger side windows. Took it to the dealer, they cleaned the channels...twice. The third trip to the dealer, they replaced the entire motors on both under warranty. Guess I wasn't the only one with this problem.
Old Oct 10, 2002 | 10:46 PM
d_warner's Avatar
Old Timer
Nothing against your post, but how in the Hell would you get a pebble inside the door to the window channel. I know anythings possible, but it is extreme.
Old Oct 11, 2002 | 04:45 AM
kirzan's Avatar
Just spray some silicone in the rubber channels that run down inside the door. You'll need to spray enough so it runs all the way down the tracks inside the door, but obviously not too much. Got rid of that hideous screech and my window now rolls down about 50% faster.
Old Oct 11, 2002 | 09:08 AM
pjandres's Avatar
It happened to me as well and ended up taking it to the dealer. They never told me the cause. (They didn't even do any paperwork, hmmm)
Old Oct 11, 2002 | 09:23 AM
NuJerseyDrive's Avatar
This is exactly how you cure this problem...
Old Oct 11, 2002 | 10:25 AM
acMAX's Avatar
so there is a solution....
same thing happens to my driver side window....pretty embarrasing
if ya ask me....
started after I got the tints done.
Old Oct 11, 2002 | 10:42 AM
Re: so there is a solution....
if ya ask me....
Yup me too. Right after getting tints, same window.
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
