starting to worry about my tranny...
Old Dec 22, 2000 | 01:17 PM
TimW's Avatar
The silent but deadly Moderator
yeah, it was a chilly 30-ish degrees and I know you guys say yours slips alittle when cold, but after about 4-5 mins of driving and the temp gauge showing warm, I went to pass and when it downshifted... *nothing*... the RPM went up about 1000, then it shifted. This is not at 5000 rpm, this is like rolling at 2000... then it 'freewheeled' up to 3000+, hung there, then shifted. I might have even heard a squeal, hard to say. total dry pavement. freaky.
the part I'm concerned about is that I were merging in traffic, I might be dead. The car didnt accelerate for about 1-2 seconds. Then for the next hour it was instantaneous shifting. I tried to see if it would happen again and it would just snap my neck shifting, like the TCM woke up and took *all* the delay out. like I had done a VB recal or something. Bizarre.
any of you with the new TCM feeling this crazy stuff?
Old Dec 22, 2000 | 01:29 PM
kpark's Avatar
I've had a few transmission problems myself. I was changing lanes in traffic and when I pressed my gas pedal to speed up into the next lane my trans dropped into 1st from 2nd with a loud clunk like the gears weren't engaged and just caught. Ever since I got my new TCM my trans seems to change gears more often than before and more than nescessary.
Old Dec 22, 2000 | 01:37 PM
TimW's Avatar
I had the 'cluck' before the
TCM. Its something the 4th gens do too.. the car has tons of torque, so the max only downshifts to first when you come to a complete stop for like a second. Its true, you can pretty much take off in second in the 5sp, so the auto does it too when it thinks its appropraite.
so if you are rolling at 5 mph and lots of throttle quickly, it will downshift brutally.
Old Dec 22, 2000 | 05:30 PM
Re: I had the 'cluck' before the
This is true. This engine has alot of torque and when it downshifts into 1st gear at a low speed-below 28mph-this car will jerk your head back. I actually like the way this transmission to start out in second from a rolling start at less than part throttle, otherwise, this car would just fly and jerk and I'd look like a fool.
So far, 11,950miles and no TCM problems *knock on wood*
Old Dec 23, 2000 | 04:13 PM
tomz17's Avatar
I came across something sorta related in the manual today(I was waiting for somebody in the car for like an hour, and had loads of spare time)
Nissan mentioned some sort of fail-safe system that would engage under extreme conditions, locking the automatic tranny in some way to prevent damage (i don't remember the exact details), but the fix would be to turn off the car, and then turn it back on, and all the problems should theoretically go away..
Not sure if this is related to your experience, but take a look in your manual when you get a chance.. (under the auto transmission section, I believe)
-Tom
Old Dec 26, 2000 | 11:50 AM
Paul6speed's Avatar
When it cold, it slips
The colder it is, the worse it is. After it slips once or twice in the morning, it's done... no more slipping for that trip. I try to take it easy when I first start out.
cruce91
Sep 20, 2015 10:23 AM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
Jay556
Sep 12, 2015 05:50 PM
trungg86
Sep 4, 2015 04:58 AM
