Injen Intake
Injen Intake
Ok I got the Injen today and installed it, looks mint! So I reset the ECM and all that, now mind you the car has only 387 miles on it so far, the MPG indicator has been hovering at 27- 28.5 MPG, after I installed the Injen it’s been around 17-21MPG! Anyone else note this I did clear it and let it recalc and it came back low again. I couldn’t tell if it made a difference in performance since I’ve not got on it yet due to mileage, although it’s not in your face like the Stillen (loud). Did I mention it looks awesome? Got the polished.
Having a new car, your mpg will improve a bit once you've broken the car in... I haven't installed my Injen CAI yet, so not sure what effect that has on the mpg. I would assume it also takes a certain amount of miles for the ECU to relearn the new intake.
well, first off that computer is not even close to accurate, so don't go by what it says. It is only reading vaccume preassure, and I am sure usually you are pretty casual with your driving. Now that you have the CAI in you are lead footing it.
Also, you cannot reset the ECU on these.... if you did then we would all love to know how, because the New ECU/ECM doesn't have a reset control and doesn't respond to disconnecting the power. The only thing that does it is driving the car for about 200 miles and/or @ 50 restarts.
With that in mind, your car is not performing right with the intake. It has to learn and use the new mapping. Give it about a week or two and you will notice one day your car just wakes up and boom it is much quicker.
Enjoy, you should enjoy this intake.
R
R
Re: Injen Intake
Tony
Originally posted by Y2KSESteve
Havin a new intake makes the gas pedal just a lil bit heavier...
Oh, and I got to see the "ICY" note pop up on my cpu screen! I didn't know our cars did that. The temp was 37 degrees this morning on the highway, so it's my first encoutner. So cool.
I fill up about 15.5 gallons, so do the math.
No lead footing yet, got the car Tuesday, took Wednesday off to cleanse paint and get two coats of Liquid Glass and Rainex on the windows. Had the wheels rebalanced, Friday had the windows tinted, installed the Injen and swapped over to Mobil 1. I might get to drive it today. Thanks for the advise, roger on the 4:20.
I just got my Injen install too!! MPG calculator is not doing much different. But do you guys hear a high pitch sound when you are flooring it in 1st at around 3000rpm to 4000rpm? sounds like blow off valve goling off, or a screw scratching somewhere. and what does your injen intake sound like when it gets pass 5500rpm? on my 2k2 it sounds like the engine is running really dry, or rough. it's not a deep low roar, but somewhat mid-high, dry roar. is this the same on all of your 2k2 6spd?
oh, i am only getting like 410 or so per fill up, 15-16 gallons. I do high way and local, mainly highway. so 480 is never been seen before in my car, not even close.
Re: Injen Intake
Re: Injen Intake
Originally posted by killer2002SE
480 miles?!?!?!??!!
OMG, im getting like 230
im on ly getting about 15 mpg at fillup...
i do city driving only, ocasional punch,
is anyone else seeing these figures?
480 miles?!?!?!??!!
Re: Re: Injen Intake
Hi Proceedbob, I just installed my Injne CAI yestarday, 2k2 6 spd. My final position of the intake is kind of weird. I was wondering if yours is the same. my secondary intake pipe is kind of slanted towards the driver's side, and it doesn't extend too far down under the hood. the end of my whole intake, or the end of the filter is right around just below the fan. there is like 1 foot or so of length until it reaches the black plastic plate thing. is this what you end up with when you are done installing? Anyone else got injen on their 2k2 6spd, feel free to jump in..... tahnks....
I just got my Injen install too!! ...But do you guys hear a high pitch sound when you are flooring it in 1st at around 3000rpm to 4000rpm? sounds like blow off valve goling off, or a screw scratching somewhere. and what does your injen intake sound like when it gets pass 5500rpm? ...
Run 1 - 2.3 meg
Run 2 - 1.8 meg
Shaydz
Originally posted by 2k2nyc
I get the same thing, 230 miles exactly!
Originally posted by Shaydz
It's not a 6 speed but if anyone looking at Injens wants to hear it from inside the cabin, I made a new camera mount (2 different angles) and took a few quick test runs. Windows and sunroof closed. (2K2 Auto)
Run 1 - 2.3 meg
Run 2 - 1.8 meg
Shaydz
Run 1 - 2.3 meg
Run 2 - 1.8 meg
Shaydz
Shaydz
Shaydz
Originally posted by BlackMax2k1
Hey Shaydz how high were you cranking the revs?
It used to shift at about 6K now it goes on up to around 6500.
The slow shift from 1st to 2nd ****es me off a little (it's always done that). Sounds almost like a slipping clutch in a manual.
Maybe I need a VB mod next? HEHEHE.
I tried to get the tach and speedometer in the shot but during the day and with the resolution, it's hard to see it. I'm going to experiment at night with the offset mount - see if its better.
KrazyD THat's with the car closed up. From outside it will spin a head or two. But if you don't WOT you can accelerate fairly quickly w/o the growl. Good sleeper mod.
I generally try to get 300 miles out of a tank (all city driving). On the road I can get 325 or a little more if I'm conservative (no more than 9 - 14 over limit).
Shaydz
Don't have a digital camera, the filter should be just to the right of the fan cage looking down between the transmission and under the battery tray. It's a real pain to get it in there, going up from the bottom with a helper would seem the call.
The best way I found was to slip it down angled under the battery, then rotate it into place. Able to not hardly touch anything.
If you have an Auto, you need to make sure you have at least an inch of clearance from the linkage cable. I posted pics of this a while ago (but can't seem to find them now). You might do a search.
Hope these pics help.
Shaydz
Originally posted by krazyd
Have you noticed any problems when the car has been running for longer periods of time (when it's hot), considering the fact that the filter is sitting right next to the transmission and engine? This is one of my concerns, b/c the PR CAI sitting outside of the engine compartment and sucks in cool air. I don't understand how the INJEN does that while being between two hot components of the car? Explain it to me, so I can make a deicison!
However, the air coming in the intake is ALWAYS cooler that what is produced in the engine compartment, thus the benefit over Pop chargers and such.
Plus the smooth bore piping and smooth angle produce a better vortex of air than say the stock monstrosity.
If you are comparing it to the PR, I'd say the fact that the piping is away from the engine on the PR will make the pipe a bit cooler, so a plus there. For me cutting a hole in my sidewall is a HUGE minus (personal opinion). If you are really concerned about the temp of a lower pipe on the Injen you can wrap it with kevlar or asbestos heat wrap. It will be oblivious of any heat off the engine.
This is not a sell, just my opinion. I know my HP is up, my car winds out farther than it did before (I have an auto) and on cold days, the power it produces is amazing - it WANTS to run strong.
I can't "explain" anything to you to make your decision - can just give you my impressions. There are hundreds of threads on this by people far brighter than I about Maximas. Give it a look.
Shaydz
Shaydz
Shaydz
I'm weary about chopping a whole into my car, but I don't understand the benefits of having a CAI if the piping gets heated. There's lot of things to think about, but i'll be making my decision soon enough. Thanks again!
I know, you're like me. That's why I asked for your opinion
It really does make a difference about how I feel about my car's power as well.
Shaydz
Tony
Originally posted by Tony Fernandes
Does it really matter if the pipe is hot? I mean, isn't the air moving through it quick enough to not be heated up? The idea that it's drawing in cooler air would be the benefit, IMO.
Tony
Tony
What if you're sitting in traffi or at a red light? Then your car is essentially sucking up all the heat of the engine. Am I right?
maxima297
Sep 30, 2015 03:32 PM
Where is the BEST place to order one?
