AUTO AC question
Old Dec 22, 2000 | 04:51 PM
01PearlGLEMAX
this is no biggy, but when i turn the degrees up or down a little, just even one degree, ALL FOUR FANS TURN ON! sometimes i cant even hear the freakin radio!! whats even wierder is...sometimes its just one fan, or two. ANY ANSWERS FOR THIS??
Old Dec 22, 2000 | 05:09 PM
Auto Temp
You can Override this by adjusting the fan speed. If you just push "mode" or the "fan speed" you don't get the A/C unless you push "Auto". The sensers are designed to heat OR cool the cabin as quickly as possible. Once it reaches the desired temperature, the fan speed slows down to 1 or 2 to maintain the temperature. +1 or -1 degrees cooler than the original setting will set the fan on or off. This is normal and you shouldn't get mad or freaked out Remember, it is an Auto climate control
Old Dec 29, 2000 | 07:40 AM
00DubbedMax
That's the purpose of Automatic Climate Control. It regulates the temperature by itself.
Old Dec 29, 2000 | 09:12 AM
rnatale's Avatar
Re: Auto Temp
I think the auto temp control is defective. All 4 fan blades should show ONLY if you make a large change in the temp. Take it back to the dealer.
2kmaximel
Nov 29, 2015 01:51 AM
bumpypickle
Sep 20, 2015 08:22 AM
pears
Sep 18, 2015 05:25 AM
