lost the use of Trip button on the steering wheel
Old Oct 14, 2002 | 04:33 AM
silverkorn's Avatar
this weekend i installed an aftermarket head unit in my car and lost use to my radio controls on the steering wheel as expected. but when i was driving to work this morning i noticed that i alos lost the use to the Trip button. is this normal or did i not hook something up correctly?
Old Oct 14, 2002 | 05:17 AM
mpc578's Avatar
this is normal, see FAQ's to get it back..
Old Oct 14, 2002 | 06:33 AM
silverkorn's Avatar
thank you i found it
http://forums.maxima.org/showthread....5&pagenumber=5
"Use of steering wheel controls with an aftermarket headunit on a 2k2/2k3.
This question has been asked quite a few times, so I am posting the answer here:
"How do I make the steering wheel controls work with an aftermarket headunit on a 2k2 or 2k3?"
This is a two step process. First you have to obtain the PAC SWI-X adapter from Crutchfield or some other mobile audio dealer. This will allow you to utilize the radio functions on the steering wheel.
Secondly, to regain use of the trip computer (the one with temp, DTE, MPG, etc.) you have to first locate the small wiring harness you removed from the stock deck, but diudn't use in the install of your aftermarket deck. This is a small harness with 4-5 wires in it. One of these wires is brown with a white stripe/marking. This wire must be cut from the harness, the stripped and grounded. I recommend grounding it to the large metal peice below the vents (you can use a small screw or electrical tape), or any other grounding site. This will now give you full use of all steering wheel controls."
lowpost99
Oct 26, 2025 06:53 PM
dcam0326
Sep 8, 2015 11:02 PM
flu2000
Sep 8, 2015 02:23 PM
coasterswim
Sep 2, 2015 07:43 AM
