Is there a way to adjust the power steering?
Old Oct 15, 2002 | 09:30 AM
soundmike's Avatar
Very sound, Mike
I've been wondering if there's any way to apply less power-assist on the steering. Road feel is just not good enough when it comes to how there's too much "assistance" from the system.
Additionally, i notice my steering wheel is slightly "loose". Best way to describe it is when i'm on the highway i can tilt the wheel left/right slightly before i feel the connection to the wheel and/or the car actually starting to drift to either direction.
Old Oct 15, 2002 | 10:31 AM
njmaxseltd's Avatar
There's no way to adjust your power steering assist. A more agressive tire, stiffer shock/struts and a perfect alignment will give you a more agressive feel to your car.
Old Oct 15, 2002 | 10:51 AM
soundmike's Avatar
Very sound, Mike
How about the underdrive pulley? Wouldn't that help a bit?
About the steering wheel being loose, it feels more like the connection between the wheel and the shaft is loose or something.
Old Oct 15, 2002 | 11:12 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: Is there a way to adjust the power steering?
there was a discussion awhile ago on the 4th gen board
refer to this post
https://maxima.org/forums/showthread...light=steering
but basicly we talked about putting in a valve in the power steering fluid system and instead of it being open all the way, open it 1/2 way or something.
There was also some discussion of maybe changing the pulley size on the pump
I have not given up on the idea, just have not had the time. I am still looking at it. If I come up with anything I'll let you know
Old Oct 15, 2002 | 11:45 AM
kramerica72's Avatar
A loose steering wheel could also be an indication of a worn steering/suspension part(i.e tie rod end, ball joint, etc..). Have someone check your front end for looseness.
Old Oct 15, 2002 | 12:51 PM
MaximaDisciple's Avatar
This has been my complaint since day one. My Max would be perfect(to me)if the power steering wasn't sooo over-boosted. I've posted this question numerous times, but apparently we're out of luck.
Old Oct 15, 2002 | 08:33 PM
Bags's Avatar
Re: Re: Is there a way to adjust the power steering?
look at th the 2nd post above yours
lowpost99
Oct 26, 2025 06:53 PM
rbarnes
Dec 31, 2015 06:29 PM
fastcarny
Oct 12, 2015 07:06 AM
ColdCananda
Sep 20, 2015 10:45 PM
Bluenissan
Sep 20, 2015 08:54 PM
