gurgling sounds...
Old Oct 19, 2002 | 10:20 AM
Maxima-Ness's Avatar
gurgling sounds...
Okay, one last thing i forgot to add...When I accelerate, the engine sounds like its gurgling. Is that just the electronic ignition or is that pinging or something else I should worry about? I use 93 octane so I dont see why it should ping. any ideas?
thanx
Old Oct 19, 2002 | 10:39 AM
2k2.6spd's Avatar
i have the same gurgle, tell me if you find a fix.
Old Oct 19, 2002 | 12:12 PM
well, im hoping someone here will tell me whats wrong, if anything is wrong. im guessing its just the EFI, as ive never had a car with that feature before.
Old Oct 19, 2002 | 01:31 PM
Green_2's Avatar
Does it sound like it's water slushing around? If it does, it might be the HVAC system. My g/f civic had the same problem. The hon-duh dealers described it as an "air pocket" within the hvac system...it seems to be fixed now...but I think it's still intermittent
Old Oct 19, 2002 | 08:07 PM
No, not exactly. It happens when I accelerate. no matter what gear im in. it just sounds like if your sucking water thru a hose with a pump or something and whatever your sucking thru the hose isnt coming thru quick enough. kinda like theres space between the stuff comeing thru the line. does that make sense? i guess you just have to hear it.
Old Oct 19, 2002 | 11:19 PM
Green_2's Avatar
Well, for the civic situation, the noise occurs at light acceleration at low speeds...meaning at about 1500 to 2000 RPM. Does the noise occur at certain RPMs?
cartman854
Feb 10, 2010 10:21 PM
foodmanry
Apr 12, 2008 05:26 PM
Monotaur
Dec 23, 2004 01:44 PM
wrongway15
Sep 28, 2003 11:59 PM
