How to read dipstick?
Old Oct 25, 2002 | 08:06 PM
Maximam's Avatar
I can't read the oil dipstick to save my life, WTF? I only know I have 4 1/2 qts by changing the oil. Any suggestions to read the dipstick?
Also just used the Bosch oil filter any comments on it? It looked to be constructed exactly like the Mobile 1 filter.
Old Oct 25, 2002 | 11:15 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
No clue myself.....
It's a bish and takes 5+ tries minimum to get 1 or 2(if I'm lucky) non-smeared reads.
The only thing I've found that works is to ONLY try when the car has been sitting overnight, otherwise it reads a quart low to a quart high.
Old Oct 25, 2002 | 11:58 PM
Maximam's Avatar
Re: No clue myself.....
Thanks!
Any comments on the Bosch filter?
Old Oct 26, 2002 | 06:54 AM
BigDogJonx's Avatar
Re: Re: No clue myself.....
Originally posted by Maximam
Thanks!
I used the Bosch filter on my last oil change and got the BlackLabs test done on the oil. Not as good as I thought.
There is this one guy that did a test on all the oil filters and still the OEM one came out to be the best cause it had the most surface area of any other filter. Wierd but true.
Dixit
Old Oct 26, 2002 | 06:57 AM
kjpierce's Avatar
here's a tip
make sure your car is level.
that dipstick is a total POS!!!
Old Oct 26, 2002 | 07:05 AM
asu174's Avatar
Clay Aiken has fancy genitals
Re: Re: Re: No clue myself.....
Dixit
Yeah, talk to Bill about oil filters. According to his testing, the best is the STP 6941 followed by the OEM ones. Apparently Fram (what I normally used before) are total crap.
Old Oct 26, 2002 | 07:08 AM
iwannabmw's Avatar
The Bosch filter looks the same as the Mobil 1 because they are both made by Champion labs on the same assembly line. The difference bewteen the Bosch and Mobil 1 is the filtration media used.
I would recommend a search on oil filters as bill99gxe has researched them extensively and posted info here.
Old Oct 26, 2002 | 09:33 AM
Maximam's Avatar
Thanks guys. The Bosch was $5 and the Mobile was $12 so I chose Bosch.
http://www.scuderiaciriani.com/rx7/oil_filter_study/
Old Oct 26, 2002 | 08:27 PM
theMax's Avatar
Re: How to read dipstick?
Seems like the engine shoots oil up the dipstick tube. Let the car sit for a while then wipe the stick and dip. Works for me, but the car has to be sittin for a while so the oil can drip down to the pan
Old Oct 26, 2002 | 09:41 PM
Maximam's Avatar
Re: Re: How to read dipstick?
Worked like a charm!!! Thanks for the help. Thanks for the replies.
mclasser
22
Nov 12, 2020 01:58 PM
chisam14
Nov 6, 2018 08:56 PM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
