turn signals out?
Old Oct 31, 2002 | 12:52 AM
MaxedOut2g's Avatar
turn signals out?
aiite i went out for dinner tonight and when i was coming back, i noticed that my headlights were on obviously, but my signals were not..both sides...however, when i would signal, they would light up...if it was just one side i would assume that the bulb was bad, but this is both sides...anybody have any ideas?
Old Oct 31, 2002 | 12:57 AM
Y2KSESteve's Avatar
Sounds like the stealth signal mod unintentionally. Thats how mine are all the time. I like it, but I have no idea why your's would be like that if you hadn't done that yourself.
Old Oct 31, 2002 | 01:21 AM
MaxedOut2g's Avatar
stealth signal? sorry i havent heard of that...im not worried about it too much, im juss kinda ****ed cuz its like WTF? why is that happening...im at like 33k miles and i need to get ALL my problems taken care of b4 thanksgiving cuz im gonna be driving home and leaving it there so i need everythign to be 100% b4 that...thanks
Old Oct 31, 2002 | 11:27 AM
studman's Avatar
I've had this happen before. It's probably just a fuse. The parking lights are controlled by a seperate fuse from the turn signals or the headlights. Check your fuses in the main cabin area to see if one is blown.
Old Oct 31, 2002 | 11:42 AM
Colonel's Avatar
Old Fuddy Duddy
If this is true, flick on your lights and check out back. Your tails should be out as well. I would check to be 100% sure. Quick way to get into an accident or get and officers attention.
Old Oct 31, 2002 | 12:18 PM
MaxedOut2g's Avatar
aiite ill check the fuses later 2nite so i can see the lights as well...anybody know what # the fuse is or what slot it would be in?
Old Oct 31, 2002 | 05:49 PM
Y2KSESteve's Avatar
STEALTH Running Lamps(FREE Mod)
Eliminates the AMBER running lamp filament on the 1157 bulb used for a 2K-2K1 headlamp, but still uses the blinker filament. This mod makes the headlamps only produce white light until the blinker is activated, which looks better in my opinion especially with clear front corners.
1)Remove the bulb/socket from the headlamp housing.
2)Remove the bulb from the socket.
3)Place SMALL piece of black electrical tape over ONE "knub"(small contact on bottom of bulb).
4)Reinstall bulb into the socket.
5)Turn on hazards(or blinker with keys in ignition). If it flashes reinstall bulb/socket into the headlamp housing, if not, remove bulb from the socket and move the electrical tape to the other "knub".
Courtesy-IceY2k1
Old Nov 1, 2002 | 07:19 PM
MaxedOut2g's Avatar
STEALTH Running Lamps(FREE Mod)....
Courtesy-IceY2k1
ooo that...yea i rememebr that...well my rear lights turn on w/ lights and i check the turn lamp fuse and its fine...is it juss my bulbs then?
Old Nov 3, 2002 | 02:06 AM
MaxedOut2g's Avatar
anybody?
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
