Question regarding Eibach Drop with 19x9.5 rims
Old Nov 4, 2002 | 09:19 AM
jhans114's Avatar
I have a customer that has 19x9.5 rims on the back of a 2001 AE and is interested in installing the Eibach pro kit. Does anyone know for a fact if there will be a rubbing problem with this set up. Thanks
Old Nov 4, 2002 | 09:24 AM
myktek's Avatar
I'll be test fitting Racing Hart C5 3 piece 18x9.5 on wed, and i have the eibach/tokico combo, hopefully that will help u out. Check www.vqpower.com i think one of the max that is featured has 19x9.5 in the rear w/ a drop, not too sure.
Old Nov 4, 2002 | 09:43 AM
jhans114's Avatar
Thanks for the info..
Old Nov 4, 2002 | 01:49 PM
PoweredbyNissan
uh..........doesn't the offset determine whether there will be rubbing? you could have a 7 inch wide wheel on a maxima and still rub with the wrong offset. correct?
Old Nov 4, 2002 | 02:26 PM
BigDogJonx's Avatar
Correct, but has to come to a point where 9.5 might start rubbing cause the wheel well is not designed to make it fit.
I gaurantee that once it is dropped and he hits a nice bump or sits 3 150lb people back there, every dip in the road will result in rubbing the inside of the wheel well plastic lining.
Dixit
Old Nov 4, 2002 | 06:48 PM
D Love's Avatar
Re: Question regarding Eibach Drop with 19x9.5 rims
If it rubs, just roll the fenders.
Old Nov 4, 2002 | 10:50 PM
freeze2k2's Avatar
Re: Re: Question regarding Eibach Drop with 19x9.5 rims
A wheel that wide will probably require a 45 or 50 offset to keep from rubbing outside. That said, with a wheel that wide a 45 or 50 offset may rub inside.
Old Nov 5, 2002 | 08:51 AM
PoweredbyNissan
so, a higher offset makes the wheel go inward? and a lower offset makes the wheel go outside more? outside meaning away from the body of the car....
Old Nov 5, 2002 | 09:01 AM
BigDogJonx's Avatar
Correct. The closer the number is to ZERO, the wheelhub for the wheel is in the center of the wheel when looking at it from the side.
a PLUS offset means it is closer to the front of the wheel. Negative offset means it is closer to the back of the wheel.
Dixit
Old Nov 5, 2002 | 12:20 PM
PoweredbyNissan
Dixit
wait a minute, so the offset determines whether the wheel moves toward teh front(the hood) or back (the trunk)? I thought it determines whether the wheel sits closer to the brake pads or farther away from the brake pad, rotors and all that.
Old Nov 5, 2002 | 12:38 PM
BigDogJonx's Avatar
No No not that way, the other way. Out means closer to the edge of the car, In meaning farther in the wheel well.
Here this will help instead of me explaining it in words, picture says it all.
http://www.tirerack.com/wheels/tech/offset.htm
Dixit
Old Nov 6, 2002 | 09:54 AM
PoweredbyNissan
Dixit
Those pictures are confusing. I saw them like a million times but I never cna understand what is drawn. Where is teh wheel exactly in that picture? is it the wheel is cut in the center, half the lug holes on one side and the other half on the other side, and we are seeing the exposed view after the slice?
Old Nov 6, 2002 | 09:08 PM
myktek's Avatar
ok, i test fitted some 18x8.5, 18x9.5 and they fit fine, just don't get tooo thick tires, it looked like the back might needed a fender roll, but it is ok. . .fyi
Old Nov 7, 2002 | 09:57 PM
Edward Lee's Avatar
What would you consider too thick of a tire for the 18x8.5? also what were the offsets of the wheels tested?
Old Nov 7, 2002 | 10:18 PM
myktek's Avatar
this is what i test fitted
18x8.5
18x9.5 +44 offset
275/40/18
245/40/18
The Frye
Sep 2, 2021 11:03 AM
captchaos
Mar 15, 2016 12:18 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
