Oxygen sensor's kaput
my service engine light came on and i checked it out. turns out it's a PO 420 (Efficiency below threshold). i'm guessing it's for the oxygen sensor. is that right? also, what's the purpose of it besides sensing oxygen?
P0420 is Right Bank 3way catalyst malfunction. Have you done any mods to your car recently? If not then it's probably just the ECU needs an update. Some 2000's had parameters for the cats programmed too tight and gave false errors. This might be happening to you. Real O2 sensor failures have been rare so far in the 5th gens.
BTW, O2 sensors read the amount of free oxygen in the exhaust stream. The ECU reads this signal and determines whether you're running lean or rich.
http://www.nhtsa.dot.gov/TSBScans/sb619999.pdf
hey, thanks sly. i haven't done any mods so u're prolly right. i thought it was that pesky oil change timer, so i disconnected the battery to reset it. then the light came back on.
man...that's a long bulletin. guess i'll print it at work...
thx
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
