6spd manual shift knob (turns)
Old Nov 11, 2002 | 06:17 PM
nismotech's Avatar
6spd manual shift **** (turns)
I've noticed that sometimes when I grab on the **** and I shift, the **** (Above the pull up ring, the round ball with 1,2,3,4,5,6,R marking) tends to turn to left or right. Is there someway I can keep it straight?
This may sound like a totally un-important question but sometime I get annoyed by it b/c I feel the need to straighten it out after I park my car
Perhabs, I should invest in a aftermarket shift ****? RAZO?
Old Nov 11, 2002 | 06:25 PM
BioMaxDDS's Avatar
Re: 6spd manual shift **** (turns)
you shoulda bought an AUTOMAGIC instead
Old Nov 11, 2002 | 06:42 PM
jagolden's Avatar
My little plastic number insert on the shift **** was loose so I removed the shifter **** to tighten the screw. When I was reinstalling the shift ****, I found I really had to turn it with a surprising amount of force in the final half turn to get the **** aligned. I almost expected something to break, but its been 8 months and its fine. It may be that you need another full turn to tighten yours.
Old Nov 11, 2002 | 07:30 PM
KL99SEA's Avatar
Yeah, mine was the same way. Just gave it another full turn clockwise and its fine. They just screw on.
Old Nov 11, 2002 | 07:36 PM
weltonw's Avatar
That's funny - I also noticed the same problem the first time today. I had just picked my car up from the dealer and noticed the **** was a little crooked (of course this is the dealer's fault!). A little twist and it was straight again.
Mine still takes a fair amount of twist to turn it, but if it becomes a problem I'll probably just try adding some tape on the stick to increase the friction.
Of course - reading further in the thread I now see that it's a just a screw that needs adjustment.
Old Nov 11, 2002 | 09:41 PM
ajahearn's Avatar
loose shifter
This happened on mine and I mentioned in on one of my drop-off's. They said they epoxied it in place. Not exactly what I wanted to hear (if I should ever decide to get it off). But it's solid now.
Old Nov 11, 2002 | 10:13 PM
SG01MaxSE's Avatar
Re: loose shifter
Ha! If YOU did that, they'd probably try to void your warranty or something!
Old Nov 12, 2002 | 12:32 AM
F8Lmax's Avatar
yup, force it one full turn around and it will stay.
Old Nov 12, 2002 | 08:27 AM
nismotech's Avatar
turn clockwise w/ one full turn, Got it!
Old Nov 12, 2002 | 10:05 AM
dblrr900's Avatar
Adding to the vote
Mine did the same. When I would give it a good shift it would damn near spin out of my hand.
Just twist it around, it is really tough, but get it around one more time, and it will never move again.
Old Nov 12, 2002 | 03:42 PM
2002MaximaSE's Avatar
I just put a small piece of paper on top of the metal shaft and screwed the **** back on. It worked great.
Old Nov 12, 2002 | 06:23 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
yup just give it a good hard turn mine ussed to but i fixed it
MAXSE5SPD
Sep 17, 2022 04:00 AM
rnb754
Sep 14, 2015 11:39 PM
LtLeary
Sep 14, 2015 12:33 PM
flu2000
Sep 8, 2015 02:23 PM
