window screeching
Old Nov 12, 2002 | 09:59 AM
kevinsean23's Avatar
window screeching
Anybody have this problem and if possible a do it your self fix?
My driver's side window screeches loudly when rolling it up. Don't think that it does it on the way down.
Well it has always done It has done this since I have gotten it. Even before I had tint.
Assistance appreciated,
Kevinsean23
Old Nov 12, 2002 | 10:45 AM
Newman's Avatar
Re: window screeching
Kevinsean23
my passenger window started screeching and shuddering on its way up after owning the car for a few months. but its been a while and it has since gone away and hasnt come back. not sure what the cause was.
Old Nov 12, 2002 | 10:54 AM
acMAX's Avatar
turn out there is a TSB for this.
Go to Nissanhelp.com and check it out.
Old Nov 12, 2002 | 12:47 PM
Punch84's Avatar
Or you can just spray some WD-40 on the part where the window meets the door. I did that and no problems since.
Dave.
Old Nov 12, 2002 | 12:53 PM
AdamK's Avatar
i actually am experiencing the same problem...what i found:
Service Bulletin Number: NTB01042
Date of Bulletin: 05/01
Component: VISUAL SYSTEMS: GLASS: POWER WINDOW DOOR AND SIDE
Summary: SUBJECT REGARDING WINDOW REGULATOR POP/TICK NOISE
ANYONE have the actual bulletin scan of this? tried google but no
Old Nov 12, 2002 | 01:51 PM
awsker's Avatar
I had the same problem but on my left passenger window. Took it to the dealer and they fixed it.
Old Nov 12, 2002 | 02:17 PM
mightima's Avatar
Same problem here, gotta bring it in tomorrow...
Old Nov 12, 2002 | 07:25 PM
victor's Avatar
Dave.
just a suggeston but never spray wd-40 on your rubber seals again. it'll dry out the rubber. it will lube it up good though. you should use a silicone based product instead. they sell a silicone lubricant spray at the hardware or auto store. i believe wd-40 is petroleum based. just a FYI.
Old Nov 12, 2002 | 07:29 PM
ToYLeT902's Avatar
JET Speed Lab
you can bring your car in the dealer for that?!
what do you say to them?
btw i think all my windows screech...
Old Nov 12, 2002 | 08:07 PM
MaximaTrojan's Avatar
yep...i agree. just spray the rubber tracks with a silicone lube. wd-40 will dry and the screech will eventually come back. don't waste your time taking it to the dealer.
Old Nov 12, 2002 | 08:16 PM
Woo Cho's Avatar
mine doesn't screech on its way up but on its way down it screeches for second.....on back driver side......but know the it doesn't make that noise anymore.....
Old Nov 12, 2002 | 08:22 PM
RBa's Avatar
RBa
Just one question. Do all of you guys have tints??
Old Nov 12, 2002 | 09:10 PM
kramerica72's Avatar
no tints and my back ones screech like a *****-
Old Nov 12, 2002 | 09:53 PM
Kal's Avatar
Kal
I hope this helps
Mine started screeching after i got my windows tinted and i posted on the org and followed the advise to WD-40 it. Well that didnt really help much so i took it to my dealer and they checked it out and ordered a part for it and put in a new one. and i havent had the problem since. This occured on both my front windows.
Old Nov 12, 2002 | 10:23 PM
maseo77's Avatar
both of my front windows do this going up and down, been putting up with this for almost a year now
Old Nov 13, 2002 | 08:08 AM
victor's Avatar
i want to get my hands on this tsb.
i've also brought my car to the dealer for the window. it got stuck in the up position and took some force by me to get it unstuck. they just lubed the window with the silicone lube. it also helps speed the window up a bit.
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
