Radar Detector......Pics
Old Nov 10, 2002 | 08:36 PM
Bulldawg's Avatar
Could everyone who has hardwired their radar in please post some pics, I am trying to get some ideas....when I searched I noticed that ppl used a "hardwire kit" and the how to's on Boosted i didn't really like how that looked, so has anyone come up with another way. Thanks
Old Nov 10, 2002 | 09:08 PM
xtantmaxima's Avatar
chop the wire off near the cigarette lighter adapter. ground one wire, hook the other wire up to a starter controlled power source in the headliner like the sunroof (only gets power when key is turned to the "On" position). If you remember the fuse rating for most of these radar detectors is 1A, so they don't draw too much power whatsoever. I noticed some new detectors come ready for hardwiring, but that is what i did to mine.
Old Nov 10, 2002 | 10:08 PM
serin's Avatar
i'm looking to do the same.. christmas gift for my car
either that or rims. big cost difference, i know..
i'm thinking of going with the escort passport 8500
Old Nov 11, 2002 | 03:03 AM
silverkorn's Avatar
you cant do that to a passport 8500 due to the fact it has more then one wire for its remote thing. they sell a hardwire kit for $30 i think.
Old Nov 11, 2002 | 08:37 AM
2MuchMAX4U's Avatar
Re: Radar Detector......Pics
I have a BEL Vector LR, I finally hardwired it. I removed the clock on the dash tapped into the acc and the negative on the clock (there's a wiring diagram on the bottom). I used some nice double sided tape and presto! Looks great email me for a picture if you want. Good Luck!
Old Nov 11, 2002 | 08:43 AM
exunaja's Avatar
V1
yes it's hard wired and it comes with the kit.
is not cheap but worth the value I have my concealed display right behind the steering wheels on the steering wheels colum.
Old Nov 11, 2002 | 10:30 AM
Eenis's Avatar
8500 easy as pie
got my 8500 hardwired. they sell just the powercord to hardwire it for i think $10, but if you want the light up thing w/ the mute button it's $30. get the $10 cord...the detector'll mute itself after a few seconds so ain't much benefit in spending the extra $20.
Old Nov 11, 2002 | 02:21 PM
vsmax's Avatar
Re: 8500 easy as pie
i dont know what kind of radar to get...any suggestions....???????
Old Nov 11, 2002 | 02:41 PM
maximadave's Avatar
detailerdaveb@gmail.com
Re: Re: 8500 easy as pie
top 3 ones are the V1, 8500, and the Bel 980.
mine hard wired above rear view mirror.
Old Nov 11, 2002 | 02:50 PM
whitam
I have an 8500 hardwired. Check http://www.5thgenmaximas.com/ under the How-To's area for info. on how to do this. I did mine slightly different, in that my "smartcord" (the $30 one) buttons I wedged into the space next to the mirror control, just remove the blank and insert smartcord. Looks nice, and you don't have to put velcro/screws/tape/etc. on top of the steering column, but you can still see the smartcord lights clearly.
Old Nov 11, 2002 | 03:46 PM
2MuchMAX4U's Avatar
Here are some pics I just took to give you an idea....
Inside
Outside
Old Nov 11, 2002 | 07:12 PM
black2kmax's Avatar
Valentine One!!! There's nothing else to consider!!
Old Nov 12, 2002 | 02:01 PM
Texasguy's Avatar
Re: Re: Radar Detector......Pics
Inside
Outside
Not working. Would love to see how this looks.
Old Nov 12, 2002 | 02:24 PM
Bags's Avatar
VG Ridah's Biatch Hoe
wrong.. I did it today.. and you can hardwire any radar dector..as long as you have a meter
here is the write up I used for the 8500
http://forums.maxima.org/showthread.php?threadid=160117
Old Nov 12, 2002 | 02:48 PM
asu174's Avatar
Clay Aiken has fancy genitals
Hardwired 8500
Old Nov 12, 2002 | 02:52 PM
Texasguy's Avatar
ASU, where did you hardwire it to?
Originally posted by asu174
Hardwired 8500
I want to do it mysefl, but I am not sure if I want to pull my dash apart. Also, do you think the level you have it is low enough to get the best coverage. I am about to take a road trip from Dallas to Alabama and don't want to get a ticket or deal with the damn cord in the way.
Old Nov 12, 2002 | 02:58 PM
max2k1SE's Avatar
To Maximadave ...
MaximaDave:
From your pic it looks like u hardwired a Bel980. I have the same detector and 2 questions for you...
(1) Does mounting it so high have any adverse effect - I was told that the blue band across the windshield top messes the detection range -- ur comments ?
(2)Anything different u did for the hardwiring - compared to the writeups provided ?
Thanks buddy !
Old Nov 12, 2002 | 03:02 PM
2002MaximaSE's Avatar
Personally I wouldn't hardwire using the cig lighter adapter. The reason is that the cig adapter and the hardwire adapter usually have a transformer in them to allow the right amount of milliamps in the unit. By bypassing this you risk blowing up the unit. I don't want to take the risk of throwing my 400 dollar V1 in the garbage.
I wired my to my auto dim mirror power. I tried wiring it to the sunroof power but the resistance was to great and the sunroof wouldn't function. I like it this way because the detector is only on when the key is in the ON position.
Old Nov 12, 2002 | 03:09 PM
Texasguy's Avatar
Unfortunately, I don't have the autodimming mirror in the 2000SE. I did this on my old truck, but the stereo shop did it as a courtesy after dropping $2K.
BTW, I am an idiot because I was too lazy to pull all the equipment out before I traded the truck in.
Old Nov 12, 2002 | 03:27 PM
asu174's Avatar
Re: ASU, where did you hardwire it to?
It was a piece of cake. I used these instructions.
http://boostedmaximas.com/howto/hardwireradar.html
It is low enough for sure. There is no tint in the way and I am guessing that I get about 1/4 mile in range most of the time.
Here is my other thingy....
Old Nov 12, 2002 | 03:30 PM
maximadave's Avatar
Re: To Maximadave ...
Originally posted by max2k1SE
MaximaDave:
Thanks buddy !
That pic was from my 2000 SE and I had no problems with range front and back. I used heavy duty velcro to mount it above the mirror. I wired it the same as the writeups here on the .orgy
I now have the same Bel 980 wired the same in my 2002 and with the window tint it has no affect on range at all. It even states this in the owners manual. Range is also great too on my 2002.
Dave
Old Nov 12, 2002 | 08:51 PM
Teser's Avatar
check out this thread
http://forums.maxima.org/showthread.php?threadid=111380
good luck.
Old Nov 13, 2002 | 06:43 AM
dmplus's Avatar
I dont know what kind of radar guns they use in your areas but laser guns are getting farily popular with the police here and it's recommended to get the detector as close to the front license plate as possible (since that's what they typically target) since the IR area typically doesnt get larger than 3 feet in diameter, having the detector up at the rv mirror may not pick any laser shots up!
Old Nov 13, 2002 | 08:20 AM
Bulldawg's Avatar
Re: Re: ASU, where did you hardwire it to?
how is your radar attached...did you just use the suction cups or what ???
Old Nov 13, 2002 | 08:53 AM
asu174's Avatar
Re: Re: Re: ASU, where did you hardwire it to?
Suction cups on the glass which work surprisingly well.
The "thingy" in the above pic was hot glued to the plastic side of a velcro strip which was then stuck to the steering wheel column.
JRod28
Feb 4, 2016 11:07 AM
99MAXSE-L
May 7, 2001 12:26 PM
_DRU_
Mar 28, 2001 07:24 PM
maxsee
Feb 2, 2001 10:17 PM
JimW
Dec 21, 2000 01:12 PM
