how to remove stock stereo??? help plz.
Old Nov 16, 2002 | 02:39 PM
Teser's Avatar
Hi.
Could someone please post a “how to” replace (remove)your stock cd/tape/radio system?
The links from the how-to faq are dead.
Did the search and came up with nothing.
Tried myself, but afraid that I break something with excessive force.
There should be a simple way but I can’t find it.
Please help!
Old Nov 16, 2002 | 02:59 PM
schuss's Avatar
there's one screw under the ash tray, and then that whole ashtray/ciglighter/shiftersurround part pops off. it's easier if you start popping at the bottom, by the shifter and work up.
then you pop off the two vents above the radio. they just pull right off. watch you don't pry against the soft dash and leave a mark.
then there's two screws under the radio assembly (behind where the ashtray surround was) and two above (behind the vent surround).
and that's seriously it. one screw, 10ish clips, and there's your radio. if they were worth stealing, i think it'd happen more...
Old Nov 16, 2002 | 05:07 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
Old Nov 17, 2002 | 08:38 AM
Teser's Avatar
thanks for the instructions!!
I'll try it out.
Old Nov 24, 2002 | 05:55 PM
Teser's Avatar
unremovable screws.
thanks again for the instructions - exacltly what I needed to know.
So I got the whole unit out, but now I'm kinda stuck. I can't remove eight screws (four on each side) that hold the tape/cd unit to the installation brackets. The screws are tightened extremely hard and I can't remove them ;((( Is there a special technique or a trick or something to remove them? Or I just have to get a good screwdriver and turn as hard as I can???
Old Nov 24, 2002 | 09:36 PM
d_warner's Avatar
Old Timer
Re: unremovable screws.
Get a fairly large tip phillips head screw driver so that you don't strip the screws out. Apply good pressure and turn it hard as #ell. They're on the radio with threadlocker or something. They will come out like normal. Trust me. Good luck man.
Old Nov 24, 2002 | 10:08 PM
Scrimbo's Avatar
Re: Re: unremovable screws.
I took a Phillips screwdriver that was the right size and was still fairly pointy, and cautiously HAMMERED it into each screw. I was then able to turn each screw out. I used a nice, long-handled screwdriver, BTW, for more torque and a better grip.
The Frye
Sep 2, 2021 11:03 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
bumpypickle
Sep 20, 2015 08:22 AM
Violator
Sep 9, 2015 10:14 AM
