Suspension Help Needed
Old Nov 25, 2002 | 04:04 PM
CBass69187's Avatar
I searched and couldn't find the answer so hopefully someone can help me out.
I recently installed H&R Spring and Tokico Blues on my car. When I turn the wheel to the right over one revolution of the steering wheel I get a sort of thump sound and this happens at low speeds. No other noises and I havent heard it turning left. Other suspension mods are RSB and FSTB.
Old Nov 25, 2002 | 07:29 PM
CBass69187's Avatar
Anyone??
Old Nov 25, 2002 | 08:45 PM
Greg's2kGLE's Avatar
Did you make sure all bolts were tightened to the correct torque specs or at least tightened till you couldn't tighten them anymore?
Old Nov 25, 2002 | 08:59 PM
bsetiawan's Avatar
Originally posted by CBass69187
Anyone??
When you put the assembly back togeether, did you put it back the way it was before ? The strut mount is slightly slanted and it happened to me once that I rotated the assembly 180 degrees when I put it back together such that the upper mount would rub against the lower mount when the steering wheel is turned. Looking at the diagram, #15 rubs against #11 when they are not properly aligned.
Old Nov 26, 2002 | 07:44 AM
CBass69187's Avatar
That seems like it is probably what it is.
Thanks!!
Russ
Matt93SE
May 24, 2019 02:58 PM
smplyamzng
Dec 13, 2015 01:19 PM
Chef N
Sep 22, 2015 11:20 PM
TonyJr
Aug 20, 2015 12:14 AM
laparka66
Aug 6, 2015 09:36 AM
